how to install steering pump pulley on a TRW pump #2061841
04/26/16 02:42 AM
04/26/16 02:42 AM
Puyallup, Wa.
Steve340 Offline OP
Steve340  Offline OP
Puyallup, Wa.
Does anyone have a 1966 manual that shows how to remove and install the pulley on a 1966 Chrysler pump. It has a hex hole on the end of the shaft. I know on the federal you thread in a bolt and nut and turn the nut to put it on, but this one has no threaded hole,just a hex hole
Re: how to install steering pump pulley on a TRW pump [Re: Steve340] #2061911
04/26/16 10:43 AM
04/26/16 10:43 AM
moparx Offline
moparx  Offline
you are in luck. pm me your email address and i will scan and send you the procedures direct from a FSM in a pdf file. is the pulley removal/installation the only info you need, or do you also need the pages describing the re-build process ?
beer
Re: how to install steering pump pulley on a TRW pump [Re: Steve340] #2062343
04/26/16 11:03 PM
04/26/16 11:03 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I have a 65 FSM, if it's the same then the tool I think you can use is
http://www.autozone.com/loan-a-tools/pow.../?checkfit=true
to pull it, you press it back on.
Don't be the exception.
Re: how to install steering pump pulley on a TRW pump [Re: Supercuda] #2062590
04/27/16 10:33 AM
04/27/16 10:33 AM
moparx Offline
moparx  Offline
that's the tool. used to pull alternator pulleys also.
beer
Re: how to install steering pump pulley on a TRW pump [Re: moparx] #2062711
04/27/16 02:26 PM
04/27/16 02:26 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
I believe the pump has to be dismantled to press the pulley back on without damaging the pump. beer
Re: how to install steering pump pulley on a TRW pump [Re: TJP] #2062798
04/27/16 05:02 PM
04/27/16 05:02 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Correct, just like an alternator, the unit must be disassembled and the rear of the pump shaft supported when pressing on the pulley.
