440 Camshaft selection and still keep power brakes. #2061352
04/25/16 01:21 PM
04/25/16 01:21 PM
Tennessee
727builder Offline OP
Tennessee
I got a guy wanting a camshaft that makes some noise but still produces enough vacuum to work his power brakes. Not looking for best all out performance cam, His car is used more for cruising and car shows. Any recommendations much appreciated. Thanks!
Re: 440 Camshaft selection and still keep power brakes. [Re: 727builder] #2061365
04/25/16 01:41 PM
04/25/16 01:41 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
You'd have to look at the specs and see which one would be better for the particular combo, but something like either of these two Howard's cams would work:
720141-12, or 721161-12
The first one(the smaller one) is probably the safer choice.
Re: 440 Camshaft selection and still keep power brakes. [Re: 727builder] #2061377
04/25/16 02:01 PM
04/25/16 02:01 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
284°/.484
Re: 440 Camshaft selection and still keep power brakes. [Re: fast68plymouth] #2061389
04/25/16 02:12 PM
04/25/16 02:12 PM
Kirkland, Washington
Pacnorthcuda Offline
those are smallblock cams
Re: 440 Camshaft selection and still keep power brakes. [Re: 727builder] #2061427
04/25/16 03:05 PM
04/25/16 03:05 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
Less than 230 duration @ .050 and an LSA of 112 or more.
And verify compression. The less he has, the less you want the duration to be.
Re: 440 Camshaft selection and still keep power brakes. [Re: 727builder] #2061497
04/25/16 04:36 PM
04/25/16 04:36 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Sounds like one of the hughes whiplash cams would be right up his alley.
Re: 440 Camshaft selection and still keep power brakes. [Re: Pacnorthcuda] #2061502
04/25/16 04:41 PM
04/25/16 04:41 PM
So. Burlington, Vt.
So. Burlington, Vt.
Page 142 of the 2015 catalog, "Chrysler big block B/RB 383-440 1959-1980 single bolt"
Re: 440 Camshaft selection and still keep power brakes. [Re: fast68plymouth] #2061538
04/25/16 05:59 PM
04/25/16 05:59 PM
Right you are.
Re: 440 Camshaft selection and still keep power brakes. [Re: fast68plymouth] #2061545
04/25/16 06:08 PM
04/25/16 06:08 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Crower 271HDP 224/232 @.050 112 centers in at 107 is a perfect hotter but not-too-hot 440 six pack replacement cam works great with power brakes, I'm assuming you'll have at least 9:1 CR?
This came up before I think it's very close to Fast68's Howards grind.
The old General Kinetics grind that SSI Industries (PAW) and Summit sells as their 'House Grind' is also very close to these specs too, a little lower lift (maybe .465?). Cheap (still under $100 IIRC)
If he wants "oooh look at me!!" sound with decent drivability, look for a Comp Thumper with similar to slightly smaller intake durations @ .050, they use a big slow exhaust ramp that sounds good (sounds like a bigger overlap cam) but is very docile.....Chevy poser boyz like them a lot, lol.
WIZE
In Car:
Re: 440 Camshaft selection and still keep power brakes. [Re: 727builder] #2061583
04/25/16 07:25 PM
04/25/16 07:25 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
One of my buddies has a 70 Challenger with Auto and power brakes/power steering. he runs the MP 292 cam. Drives it everywhere cruise inns and the drag strip.Has no issues with it at all.
Old Geezer Racing
Re: 440 Camshaft selection and still keep power brakes. [Re: 727builder] #2061656
04/25/16 09:19 PM
04/25/16 09:19 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
You didn't say if you wanted mech or hydraulic cam but we run this one in my brothers 440 Cuda
Comp Cams 21-232-4
244 int 250 exh
Its installed at 106, has power brakes and no issues.
Ok
Re: 440 Camshaft selection and still keep power brakes. [Re: cudatom] #2061771
04/26/16 12:19 AM
04/26/16 12:19 AM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
I had a Mopar .484 cam in my old 440, car ran and sounded good. It had power brakes and steering. Recently put a Whiplash cam in my dads Roadrunner, big mistake.
The only Carbs I care about are under the hood!
Re: 440 Camshaft selection and still keep power brakes. [Re: Azzkikrcuda] #2062121
04/26/16 05:14 PM
04/26/16 05:14 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
What do you not like about the Whiplash? 383 or 440?
