Re: 440 Camshaft selection and still keep power brakes.
[Re: 727builder]
#2061365
04/25/16 01:41 PM
04/25/16 01:41 PM
Posts: 14,492 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
You'd have to look at the specs and see which one would be better for the particular combo, but something like either of these two Howard's cams would work: 720141-12, or 721161-12 The first one(the smaller one) is probably the safer choice.
[Re: fast68plymouth]
#2061389
04/25/16 02:12 PM
04/25/16 02:12 PM
Posts: 21,814 Kirkland, Washington
Pacnorthcuda
You'd have to look at the specs and see which one would be better for the particular combo, but something like either of these two Howard's cams would work: 720141-12, or 721161-12 The first one(the smaller one) is probably the safer choice. those are smallblock cams
[Re: 727builder]
#2061427
04/25/16 03:05 PM
04/25/16 03:05 PM
Posts: 8,936 Holly/MI
Dean_Kuzluzski
Holly/MI
Less than 230 duration @ .050 and an LSA of 112 or more. And verify compression. The less he has, the less you want the duration to be.
[Re: Pacnorthcuda]
#2061502
04/25/16 04:41 PM
04/25/16 04:41 PM
fast68plymouth
So. Burlington, Vt.
You'd have to look at the specs and see which one would be better for the particular combo, but something like either of these two Howard's cams would work: 720141-12, or 721161-12 The first one(the smaller one) is probably the safer choice. those are smallblock cams Page 142 of the 2015 catalog, "Chrysler big block B/RB 383-440 1959-1980 single bolt"
#2061538
04/25/16 05:59 PM
04/25/16 05:59 PM
Pacnorthcuda
You'd have to look at the specs and see which one would be better for the particular combo, but something like either of these two Howard's cams would work: 720141-12, or 721161-12 The first one(the smaller one) is probably the safer choice. those are smallblock cams Page 142 of the 2015 catalog, "Chrysler big block B/RB 383-440 1959-1980 single bolt" Right you are.
[Re: 727builder]
#2061583
04/25/16 07:25 PM
04/25/16 07:25 PM
Posts: 1,505 TN
SCATPACK 1
TN
One of my buddies has a 70 Challenger with Auto and power brakes/power steering. he runs the MP 292 cam. Drives it everywhere cruise inns and the drag strip.Has no issues with it at all.
Old Geezer Racing
[Re: 727builder]
#2061656
04/25/16 09:19 PM
04/25/16 09:19 PM
Posts: 1,098 Massillon, Ohio
cudatom
Massillon, Ohio
You didn't say if you wanted mech or hydraulic cam but we run this one in my brothers 440 Cuda Comp Cams 21-232-4 244 int 250 exh Its installed at 106, has power brakes and no issues.
Ok
[Re: cudatom]
#2061771
04/26/16 12:19 AM
04/26/16 12:19 AM
Posts: 1,807 North Dakota
Azzkikrcuda
North Dakota
I had a Mopar .484 cam in my old 440, car ran and sounded good. It had power brakes and steering. Recently put a Whiplash cam in my dads Roadrunner, big mistake.
The only Carbs I care about are under the hood!
[Re: Azzkikrcuda]
#2062121
04/26/16 05:14 PM
04/26/16 05:14 PM
Posts: 1,565 tennessee
pushbutton
tennessee
I had a Mopar .484 cam in my old 440, car ran and sounded good. It had power brakes and steering. Recently put a Whiplash cam in my dads Roadrunner, big mistake. What do you not like about the Whiplash? 383 or 440?
