Broke my engine in, it was too lean (vacuum leak)any damage?
#2058768
04/21/16 01:18 AM
04/21/16 01:18 AM
Posts: 4,930 Tri-Cities, Washington
VITC_GTX
Broke in my rebuild 383 with a 650 Edelbrock. It ran a little warm during break-in but never actually overheated, it was close though. I noticed today that the rear plug wasn't in the carb so I had a large vacuum leak. Did I do any short-term/long-term damage breaking it in that lean??
Re: Broke my engine in, it was too lean (vacuum leak)any damage?
[Re: VITC_GTX]
#2058826
04/21/16 03:37 AM
04/21/16 03:37 AM
Posts: 5,164 CT
GTX MATT
CT
Not a problem, no different than having a PCV hooked up...
[Re: GTX MATT]
#2058928
04/21/16 12:11 PM
04/21/16 12:11 PM
RapidRobert
it likely will be buggin you till you get something concrete to wrap your mind around. I'd pull the plug to replicate it again & shoot the ex manifolds & see how hot they get (just me my OCD would not be at peace till I did SOMETHING!)
[Re: dogdays]
#2059087
04/21/16 03:42 PM
04/21/16 03:42 PM
RapidRobert
What Dog said, I'd do a compression test (& a leakdown test) just to have some numbers for a future reference baseline (& the C test would give you a DCR indicator)
[Re: dogdays]
#2059128
04/21/16 04:41 PM
04/21/16 04:41 PM
Posts: 5,164 CT
GTX MATT
CT
It IS different from having a PCV valve hooked up, the valve closes at high vacuum, an open hole doesn't.
True but it shouldnt close all the way... I get your point. So his leak is a little bigger. Bottom line is he has nothing to worry about. Don't let Moparts scare you. I'm surprised someone hasn't already recommended taking it back apart...
[Re: VITC_GTX]
#2059161
04/21/16 05:29 PM
04/21/16 05:29 PM
Posts: 4,952 northwest USA
NANKET
northwest USA
Yeah really, and convert to a volt meter, mini starter, electronic ignition, 11X3 rear brakes, etc. LOL.
The engine will be fine, washing it down with too rich a mixture is what causes problems, especially on a new engine.
[Re: VITC_GTX]
#2059247
04/21/16 08:12 PM
04/21/16 08:12 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
If it ain't broke don't fix it and don't go looking for trouble if it isd running good and has no outward sign of damage.
Clean it, if it's Dirty. Oil it, if it Squeaks.
But: Don't fix it, if it Works!
[Re: VITC_GTX]
#2059496
04/22/16 03:00 AM
04/22/16 03:00 AM
RapidRobert
Sounds like a few of you are like me (OCD) and would to be able to PROVE nothing is wrong. I think I will try and put my mind to rest and just drive the stupid thing. Holler how that works for you!
[Re: VITC_GTX]
#2059620
04/22/16 12:23 PM
04/22/16 12:23 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
I will try and put my mind to rest Compression&leak-down ends the speculation... 'Know' trumps 'wonder'...
[Re: VITC_GTX]
#2059638
04/22/16 12:43 PM
04/22/16 12:43 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
Once I forgot to fill up the antifreeze before an engine fire up... wasn't empty, but the gauge pegged, didn't hurt a thing.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: RSNOMO]
#2059675
04/22/16 01:44 PM
04/22/16 01:44 PM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
I will try and put my mind to rest Compression&leak-down ends the speculation... 'Know' trumps 'wonder'... Puh-lease. Just check the plugs and call it a day.
When it takes more than a sweet mullet to prove you rule at the trailer park..
