Broke my engine in, it was too lean (vacuum leak)any damage? #2058768
04/21/16 01:18 AM
04/21/16 01:18 AM
Tri-Cities, Washington
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Broke in my rebuild 383 with a 650 Edelbrock. It ran a little warm during break-in but never actually overheated, it was close though. I noticed today that the rear plug wasn't in the carb so I had a large vacuum leak. Did I do any short-term/long-term damage breaking it in that lean??
Re: Broke my engine in, it was too lean (vacuum leak)any damage? [Re: VITC_GTX] #2058770
04/21/16 01:21 AM
04/21/16 01:21 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Probably not.
Re: Broke my engine in, it was too lean (vacuum leak)any damage? [Re: VITC_GTX] #2058803
04/21/16 02:25 AM
04/21/16 02:25 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Better lean than rich. If the plug was out of the carb then all cyl had the same mixture, which is good. It did not overheat so it is probably fine.
Re: Broke my engine in, it was too lean (vacuum leak)any damage? [Re: VITC_GTX] #2058826
04/21/16 03:37 AM
04/21/16 03:37 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Not a problem, no different than having a PCV hooked up...
Re: Broke my engine in, it was too lean (vacuum leak)any damage? [Re: GTX MATT] #2058928
04/21/16 12:11 PM
04/21/16 12:11 PM
it likely will be buggin you till you get something concrete to wrap your mind around. I'd pull the plug to replicate it again & shoot the ex manifolds & see how hot they get (just me my OCD would not be at peace till I did SOMETHING!)
Re: Broke my engine in, it was too lean (vacuum leak)any damage? [Re: VITC_GTX] #2058937
04/21/16 12:31 PM
04/21/16 12:31 PM
Oregon City, OR
Baxter61 Offline
Baxter61  Offline
Oregon City, OR
motor wasnt under load, youre probably ok
Re: Broke my engine in, it was too lean (vacuum leak)any damage? [Re: VITC_GTX] #2058949
04/21/16 12:49 PM
04/21/16 12:49 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
The real question is did you go out and do a big burn out yet?
Re: Broke my engine in, it was too lean (vacuum leak)any damage? [Re: Mr.Yuck] #2059068
04/21/16 03:12 PM
04/21/16 03:12 PM
dogdays Offline
dogdays  Offline
It IS different from having a PCV valve hooked up, the valve closes at high vacuum, an open hole doesn't.
I'd just run the thing.
BUT, if your OCD is at the same level as Blazin' Bob's, I'd recommend a compression check. The extra heat usually affects the exhaust valve first. So if the exhaust valve seals, everything else should be good.
No worries.
R.
Re: Broke my engine in, it was too lean (vacuum leak)any damage? [Re: dogdays] #2059087
04/21/16 03:42 PM
04/21/16 03:42 PM
What Dog said, I'd do a compression test (& a leakdown test) just to have some numbers for a future reference baseline (& the C test would give you a DCR indicator)
Re: Broke my engine in, it was too lean (vacuum leak)any damage? [Re: dogdays] #2059128
04/21/16 04:41 PM
04/21/16 04:41 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
True but it shouldnt close all the way... I get your point. So his leak is a little bigger. Bottom line is he has nothing to worry about. Don't let Moparts scare you. I'm surprised someone hasn't already recommended taking it back apart...
Re: Broke my engine in, it was too lean (vacuum leak)any damage? [Re: VITC_GTX] #2059161
04/21/16 05:29 PM
04/21/16 05:29 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Yeah really, and convert to a volt meter, mini starter, electronic ignition, 11X3 rear brakes, etc. LOL.
The engine will be fine, washing it down with too rich a mixture is what causes problems, especially on a new engine.
Re: Broke my engine in, it was too lean (vacuum leak)any damage? [Re: VITC_GTX] #2059247
04/21/16 08:12 PM
04/21/16 08:12 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
If it ain't broke don't fix it and don't go looking for trouble if it isd running good and has no outward sign of damage.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: Broke my engine in, it was too lean (vacuum leak)any damage? [Re: VITC_GTX] #2059486
04/22/16 02:38 AM
04/22/16 02:38 AM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Thanks for the help guys. I was hoping I was OK.
Sounds like a few of you are like me (OCD) and would to be able to PROVE nothing is wrong. I think I will try and put my mind to rest and just drive the stupid thing.
Re: Broke my engine in, it was too lean (vacuum leak)any damage? [Re: VITC_GTX] #2059496
04/22/16 03:00 AM
04/22/16 03:00 AM
Holler how that works for you!
Re: Broke my engine in, it was too lean (vacuum leak)any damage? [Re: VITC_GTX] #2059620
04/22/16 12:23 PM
04/22/16 12:23 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Compression&leak-down ends the speculation...
'Know' trumps 'wonder'...
Re: Broke my engine in, it was too lean (vacuum leak)any damage? [Re: VITC_GTX] #2059638
04/22/16 12:43 PM
04/22/16 12:43 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
Once I forgot to fill up the antifreeze before an engine fire up... wasn't empty, but the gauge pegged, didn't hurt a thing.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Broke my engine in, it was too lean (vacuum leak)any damage? [Re: VITC_GTX] #2059674
04/22/16 01:43 PM
04/22/16 01:43 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Should run straight water at first, verify no leaks, then install anitfreeze that first day.
Re: Broke my engine in, it was too lean (vacuum leak)any damage? [Re: RSNOMO] #2059675
04/22/16 01:44 PM
04/22/16 01:44 PM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
Puh-lease. eyes
Just check the plugs and call it a day.
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: Broke my engine in, it was too lean (vacuum leak)any damage? [Re: VITC_GTX] #2059773
04/22/16 04:07 PM
04/22/16 04:07 PM
Vista, California
67Satty Offline
67Satty  Offline
Vista, California
I did something similar, maybe even worse when I broke in my 440 a few years ago. One of the plugs in my Edelbrock Performer RPM was missing and I didn't catch it. After fixing it, I decided to just run it and not look back. 100 1/8 miles passes later, it's still going strong.
