Re: Sound Deadener [Re: mopowers] #2053342
04/13/16 01:45 AM
04/13/16 01:45 AM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
I've heard stories and seen pictures of that peel and seal stuff melting and dripping from vertical surfaces a while after being installed. I'm staying away from that stuff and sticking to Butyl based stuff. I ended up buying some of the amazon Noico stuff. I plan of scattering pieces just to kill some resonance. I figure it's better than nothing.
Re: Sound Deadener [Re: mopowers] #2053550
04/13/16 11:49 AM
04/13/16 11:49 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
To recap here, there are three primary ways you effect sound transmission, a. you reflect it, by increasing the rigidity of the surface b. you slow it down/lower its frequency by increasing the mass of the barrier, c. you absorb a portion of it, which is usually very frequency dependent, ie Fiberglas does well on higher frequencies, asphalt/lead does well on lower frequencies, with a lot of options in between, and finally d. a mixed combination of all the above as buyer chooses. There is no magic here, just some guess luckier then others. twocents
Re: Sound Deadener [Re: mopowers] #2054634
04/14/16 11:00 PM
04/14/16 11:00 PM
Spokane Valley, WA
Big Bad Bee Offline
Big Bad Bee  Offline
Spokane Valley, WA
Was it peal and seal product? I'd enjoy seeing proof. I did a tons of searching online and never read a thing about dripping. Pealing? I don't believe it. The stuff is made to seal porous surfaces on your roof. If you applied some you'd know how sticky it is. Trust me. It's going to be a PITA to remove. The funniest part of the dripping claim is that the stuff comes in a roll that sits vertically on the shelf... i doubt they would sell it that way if it dripped. I guess I'll give an update a couple years down the road. Hope what you bought works well for you.
I’m listening.
Re: Sound Deadener [Re: mopowers] #2054650
04/14/16 11:21 PM
04/14/16 11:21 PM
BDW Offline
BDW  Offline
Good tip, I'm always up for saving some money.
Did you use the Peal & Seal for noise or heat?
Did you notice a reduction in noise levels?
I tried to PM you , but your in box is full.
Re: Sound Deadener [Re: Big Bad Bee] #2054657
04/14/16 11:30 PM
04/14/16 11:30 PM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
I never said anything about the stuff peeling. I've just seen the stuff drip. No thanks. My friend was cleaning his doors out for a while to get that crap outta there. I don't have any pics from his debacle, I did a quick online search. I hope you don't have any issues with it. Good luck.
http://www.diymobileaudio.com/forum/general-car-audio-discussion/233106-home-depot-peel-n-seal.html
http://www.mobilesoundscience.com/showth...03804d008a9af07
Re: Sound Deadener [Re: mopowers] #2054781
04/15/16 05:07 AM
04/15/16 05:07 AM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
I heard it said, "A picture is worth a thousand words".
Re: Sound Deadener [Re: mopowers] #2055488
04/16/16 12:39 PM
04/16/16 12:39 PM
Spokane Valley, WA
Big Bad Bee Offline
Big Bad Bee  Offline
Spokane Valley, WA
Was it peal and seal product? I'd enjoy seeing proof. I did a tons of searching online and fnever read a thing about dripping. Pealing? I don't believe it. The stuff is made to seal porous surfaces on your roof. If you applied some you'd know how sticky it is. Trust me. It's going to be a PITA to remove. The funniest part of the dripping claim is that the stuff comes in a roll that sits vertically on the shelf... i doubt they would sell it that way if it dripped. I guess I'll give an update a couple years down the road. Hope what you bought works well for you.
Well I guess your friend found the limits of that product! Yeah. Don't put it on panels directly exposed to daylight. I'm using it on the floors. Wouldn't even dream about putting it on the underside of a deck lid like the guy in the photo. That's like asking it to stick to a hot frying pan! I guess we'll see how my firewall does. That's the hottest area I've got it on.
I’m listening.
Re: Sound Deadener [Re: BDW] #2055489
04/16/16 12:41 PM
04/16/16 12:41 PM
Spokane Valley, WA
Big Bad Bee Offline
Big Bad Bee  Offline
Spokane Valley, WA
Go for it now. I clears it out a bit.
I’m listening.
Re: Sound Deadener [Re: mopowers] #2055559
04/16/16 02:55 PM
04/16/16 02:55 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Directly from Peel and Seal's installation instructions
"Service Temperature -25° - 200° F"
Scroll to bottom
http://www.mfmbp.com/purchase/store/tabid/81/ProdID/2/Peel_and_Seal.aspx
I call BS on the drips. Someone might be using something they are calling Peel and Seal, but it's probably not it.
Dynamat says
"Dynamat is a patented, lightweight elastomeric butyl and aluminum constrained-layer vibration damper. Dynamat conforms and fuses easily to sheet metal and other hard substrates. Material performance is optimized for temperature ranges between 14°F and 140°F (- 10°C to +60°C). Material can withstand temperature extremes between -65°F and +300°F (-54°C to +149°C) and is highly resistant to aging."
Looks like their service temp is 14F to 140F, peel and seal doesn't list a maximum temperature though, not that I can find anyway.
I seriously doubt someone's car gets any hotter than someone's roof, especially with peel and seal on the inside of the car.
Don't be the exception.
Re: Sound Deadener [Re: mopowers] #2055862
04/17/16 12:31 AM
04/17/16 12:31 AM
Ohio
lockjaw-express Offline
Ohio
I just bought and installed Dynamat Extreme and Dynamat Superlite in both my '32 Ford and my '69 GTX. I am very impressed with how it bonds to the painted steel, and it bonds very well to just primed steel as well.
I talked to several interior upholstery companies at the NSRA show in Columbus, and they all told me not to waste my money trying to save money on other products. They also told me that the bonding material will literally soak into and become part of the steel.
If I am already spending big bucks on my classic cars, why not just by the best and be done with it.
My 2 cents, Mark
Re: Sound Deadener [Re: Supercuda] #2055941
04/17/16 02:16 AM
04/17/16 02:16 AM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Scroll to bottom
Dynamat says
It's probably fine on a horizontal surface like a floor board. I wouldn't trust it on a vertical surface like a door though. I've seen the drips. Good luck.
Re: Sound Deadener [Re: mopowers] #2055997
04/17/16 08:46 AM
04/17/16 08:46 AM
Port Huron, Michigan
MI_Custumz Offline
MI_Custumz  Offline
Saw on one of the many car tv shows that they used peel and stick duct insulation. Wonder how that would work? Not the tar kind. Not sure if this was it or not. http://www.homedepot.com/p/E-O-12-in-x-15-ft-Self-Stick-Foam-Foil-Duct-Insulation-FV516/100028603
Re: Sound Deadener [Re: MI_Custumz] #2056017
04/17/16 11:01 AM
04/17/16 11:01 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I used tinted bedliner (RaptorLiner) to serve as my first layer of noise reduction. I expect it to significantly cut down on resonance throughout the interior and provide a durable surface for actually putting stuff in the trunk.
I will likely add something additional for heat rejection before I am through however. Firewall, forward floors and the roof.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Sound Deadener [Re: mopowers] #2056043
04/17/16 12:06 PM
04/17/16 12:06 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
I'm a firm believer in this stuff
Used it in the past 3 or 4 cars I've done. It makes a HUGE difference
www.Fatmat.com
I use the Rattle Trap version
Re: Sound Deadener [Re: lockjaw-express] #2056049
04/17/16 12:11 PM
04/17/16 12:11 PM
Spokane Valley, WA
Big Bad Bee Offline
Big Bad Bee  Offline
Spokane Valley, WA
My 2 cents, Mark
Real good point and If you have the cash and you're doing a top shelf resto, I agree. Buy the best. I would love to put in the cool stuff. I won't get my car done before I retire if I go that route. My goal on the entire build is to save 50%-75% on everything. So I rebuilt my transmission myself, I restore parts instead of buying new, I've become a master at parts cross-compatibility and will I install roof flashing to save a couple hundred bucks under the carpet where nobody will ever see? Oh yes I will! And the thrill of going this route and learning as I go has been a BLAST!
I’m listening.
Re: Sound Deadener [Re: mopowers] #2056110
04/17/16 01:40 PM
04/17/16 01:40 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
One point that needs mentioned. Priciest choice is no indication of best choice, unless your sole criteria for best is price.
Best choice can have many answers. Compared to the stock sound deadening on my 65 Cuda, ANYTHING is an improvement. Compared to a bank vault, they all fail.
You pick that which you are most comfortable with and that is the best choice, for you.
Re: Sound Deadener [Re: Supercuda] #2056645
04/18/16 10:21 AM
04/18/16 10:21 AM
moparx Offline
moparx  Offline
iagree the best answer.
beer
Re: Sound Deadener [Re: Supercuda] #2056812
04/18/16 03:15 PM
04/18/16 03:15 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Self-adhesive sound deadener is only the first step in the process. If you don't utilize a secondary insulating blanket-like substance such as The Insulator, you are only doing half the job.
By the way, when I close the door on my '70, which was done with this method, it sounds like you are in a bank vault.(might as well be for as much as these cars are worth these days) This has been the description of many a person who asked if they can sit in the car at car shows.
