Noisy pcv #205399
01/26/09 09:02 PM
01/26/09 09:02 PM
Texas, USA
jlhram Offline OP
jlhram  Offline OP
Texas, USA
I recently did a cam swap on my 69 383. went from a 284 to a 268. Car ran fine for a couple days and then it started running rough and the pcv valve is rattling like crazy. I checked for intake leak and found none. I checked vac. and got about 18 but it is not steady the needle shakes a lot. I tried moving the pcv hose from the front to the back of the carb and it seemed to geta little better but still surges. I have heard from friends and relatives that this is the best place to get good sound advice, so thank you in advance. Jim
2011 Dodge Charger 1969 383 Roadrunner 2003 Dodge ram Hemi
Re: Noisy pcv [Re: jlhram] #205400
01/26/09 09:04 PM
01/26/09 09:04 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Have you reset your timing and carb since the change?
Re: Noisy pcv [Re: stumpy] #205401
01/26/09 09:54 PM
01/26/09 09:54 PM
Texas, USA
jlhram Offline OP
jlhram  Offline OP
Texas, USA
Thanks stumpy, yes after initial break in the timing was adjusted and as for the carb, really didn't have to do much but adjust the idle. Like I said the strange thing was I drove it for a couple days before this started.
Re: Noisy pcv [Re: jlhram] #205402
01/27/09 12:02 AM
01/27/09 12:02 AM
San Francisco Ca
SCATPK Offline
SCATPK  Offline
San Francisco Ca
Is it sealing well into the valvecover?
Re: Noisy pcv [Re: jlhram] #205403
01/27/09 12:28 AM
01/27/09 12:28 AM
I would continue to search for a vac leak. Possibly intake valley pan
Re: Noisy pcv [Re: jlhram] #205404
01/27/09 12:31 AM
01/27/09 12:31 AM
East of nowhere
41hemi Offline
Wife thinks I am Crazy!
41hemi  Offline
East of nowhere
Run a compression check
Re: Noisy pcv [Re: 41hemi] #205405
01/27/09 09:19 AM
01/27/09 09:19 AM
Franklin Co. Illinois
runinonmt Offline
runinonmt  Offline
That thing got a hemi? Just Kiddin'. Check the hose and carb fitting for blockage. Also check the filtered cap on the other valve cover. If the vacuum gauge read a bouncy 18 a leak is likely, though it may come from the pcv. Try restricting the hose a bit until the rattle stops. If it all checks out try the suggestion at the end of this thread: https://board.moparts.org/ubbthreads/show...amp;Search=true
Say hi to Gail & the grandkids for me. Need to get down there for my parts and
Ron
P.S. if the link doesn't work do a search for "pcv valve"
Re: Noisy pcv [Re: runinonmt] #205406
01/27/09 09:25 PM
01/27/09 09:25 PM
Texas, USA
jlhram Offline OP
jlhram  Offline OP
Texas, USA
Thanks I'll see what I can come up with and let you know. Ron ur parts are safe and FROZEN.
Re: Noisy pcv [Re: jlhram] #205407
01/27/09 11:33 PM
01/27/09 11:33 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I had the fluttering PCV problem too. I think just too much air was going through it after my rebuild. I shoved a restrictor(an old 1/4" drive socket) into the rubber line by the carb and that cured it.
