Re: Noisy pcv
[Re: jlhram]
#205403
01/27/09 12:28 AM
01/27/09 12:28 AM
RapidRobert
I would continue to search for a vac leak. Possibly intake valley pan
Re: Noisy pcv
[Re: 41hemi]
#205405
01/27/09 09:19 AM
01/27/09 09:19 AM
Posts: 416 Franklin Co. Illinois
runinonmt
That thing got a hemi? Just Kiddin'. Check the hose and carb fitting for blockage. Also check the filtered cap on the other valve cover. If the vacuum gauge read a bouncy 18 a leak is likely, though it may come from the pcv. Try restricting the hose a bit until the rattle stops. If it all checks out try the suggestion at the end of this thread: https://board.moparts.org/ubbthreads/show...amp;Search=trueSay hi to Gail & the grandkids for me. Need to get down there for my parts and Ron P.S. if the link doesn't work do a search for "pcv valve"
Re: Noisy pcv
[Re: runinonmt]
#205406
01/27/09 09:25 PM
01/27/09 09:25 PM
Posts: 10 Texas, USA
jlhram
Texas, USA
Thanks I'll see what I can come up with and let you know. Ron ur parts are safe and FROZEN.
2011 Dodge Charger
1969 383 Roadrunner
2003 Dodge ram Hemi
Re: Noisy pcv
[Re: jlhram]
#205407
01/27/09 11:33 PM
01/27/09 11:33 PM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
I had the fluttering PCV problem too. I think just too much air was going through it after my rebuild. I shoved a restrictor(an old 1/4" drive socket) into the rubber line by the carb and that cured it.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
