Belt squeals when a/c compressor turns on 2002 Concord #2053689
04/13/16 03:18 PM
04/13/16 03:18 PM
USA
K
krw71ragtop Offline OP
K
USA
This is a 2002 Concord, 3.5 engine, new belt, 80,000 miles. Every time the a/c compressor kicks on the belt squeals. It started doing this last year. Doesn't do it in the winter or when it's cold but the warmer it gets the louder and longer it squeals. Anyone experience this or know how to fix it ?
Re: Belt squeals when a/c compressor turns on 2002 Concord [Re: krw71ragtop] #2053764
04/13/16 05:23 PM
04/13/16 05:23 PM
P
Paul_Fancsali Offline
P
Could be over charged or tight inside , but my guess is the clutch itself It probably has rust on outer ring that is making noise on engagement Tough to say without hearing the noise
Re: Belt squeals when a/c compressor turns on 2002 Concord [Re: Paul_Fancsali] #2053897
04/13/16 10:07 PM
04/13/16 10:07 PM
IN
ahy Offline
ahy  Offline
IN
One common cause would be the belt is worn, glazed or contaminated by oil. If not done recently, suggest you replace the belt with a Gates or similar high quality belt.
Re: Belt squeals when a/c compressor turns on 2002 Concord [Re: krw71ragtop] #2053942
04/13/16 11:03 PM
04/13/16 11:03 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
So how often do you run the a/c on in the winter ?
Re: Belt squeals when a/c compressor turns on 2002 Concord [Re: Stanton] #2053955
04/13/16 11:24 PM
04/13/16 11:24 PM
USA
K
K
USA
The a/c compressor kicks on and off when the heater and the a/c is turned on. Apparently this is a Chrysler design. Even though I don't use the a/c in the winter, I do have to use the heater ! I'm sure the belt still slips but do to the cold it doesn't make the noise. When the switch is in the off position, no belt noise !
I purchased the car with 12,000 miles on it and have done all maintenance.
Re: Belt squeals when a/c compressor turns on 2002 Concord [Re: ahy] #2053957
04/13/16 11:26 PM
04/13/16 11:26 PM
USA
K
K
USA
It has a new Gates belt
Re: Belt squeals when a/c compressor turns on 2002 Concord [Re: krw71ragtop] #2053975
04/13/16 11:46 PM
04/13/16 11:46 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Worn/weak tensioner
Re: Belt squeals when a/c compressor turns on 2002 Concord [Re: mopars4ever] #2054012
04/14/16 12:33 AM
04/14/16 12:33 AM
IN
ahy Offline
ahy  Offline
IN
Good idea to pull the belt and check all accessories - including the tensioner - for free and quiet movement. My daughters '01 Jeep had a similar problem and the alternator bearings were shot. It ran a surprising long time that way but they were tight. Reman alternator and it was quiet again.
Re: Belt squeals when a/c compressor turns on 2002 Concord [Re: krw71ragtop] #2057920
04/19/16 09:47 PM
04/19/16 09:47 PM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
99 Caravan here, same thing, buy mine screams. I'm thinking new compressor too.
Re: Belt squeals when a/c compressor turns on 2002 Concord [Re: krw71ragtop] #2057938
04/19/16 10:06 PM
04/19/16 10:06 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I had a 93 3.0 mini van and the belt would scream on occasion and I replaced the tensioner and all was good.
Re: Belt squeals when a/c compressor turns on 2002 Concord [Re: mopars4ever] #2058976
04/21/16 01:29 PM
04/21/16 01:29 PM
fredericksburg,va
fredericksburg,va
Might try that, got a couple
