Re: Belt squeals when a/c compressor turns on 2002 Concord
[Re: Stanton]
#2053955
04/13/16 11:24 PM
04/13/16 11:24 PM
Posts: 892 USA
krw71ragtop
USA
The a/c compressor kicks on and off when the heater and the a/c is turned on. Apparently this is a Chrysler design. Even though I don't use the a/c in the winter, I do have to use the heater ! I'm sure the belt still slips but do to the cold it doesn't make the noise. When the switch is in the off position, no belt noise !
I purchased the car with 12,000 miles on it and have done all maintenance.
[Re: ahy]
#2053957
04/13/16 11:26 PM
04/13/16 11:26 PM
Posts: 892 USA
krw71ragtop
USA
It has a new Gates belt One common cause would be the belt is worn, glazed or contaminated by oil. If not done recently, suggest you replace the belt with a Gates or similar high quality belt.
[Re: krw71ragtop]
#2053975
04/13/16 11:46 PM
04/13/16 11:46 PM
Posts: 13,585 md
mopars4ever
md
[Re: mopars4ever]
#2058976
04/21/16 01:29 PM
04/21/16 01:29 PM
Posts: 8,257 fredericksburg,va
cudaman1969
fredericksburg,va
I had a 93 3.0 mini van and the belt would scream on occasion and I replaced the tensioner and all was good. Might try that, got a couple
