Cam break in lube question #2049694
04/08/16 02:12 PM
04/08/16 02:12 PM
Martinsville, IN
cdwmotorsports Offline OP
Martinsville, IN
Does anyone still make and sell the red lube that gets on everything and seems to wind up everywhere? I have bought three different bottles of lube but the are all a zinc additive lube, Howard's, Lucas etc.
eBay-cdwmotorsports
Re: Cam break in lube question [Re: cdwmotorsports] #2049757
04/08/16 03:24 PM
04/08/16 03:24 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I use the Torco red............
Re: Cam break in lube question [Re: cdwmotorsports] #2049765
04/08/16 03:32 PM
04/08/16 03:32 PM
new york usa
P
pattyboy 572 Offline
P
new york usa
Isky cams...http://www.summitracing.com/parts/isk-xpl-216..welcome to 2016
Re: Cam break in lube question [Re: pattyboy 572] #2049810
04/08/16 04:25 PM
04/08/16 04:25 PM
Washington
madscientist Offline
Washington
All the Isky stuff I have is probably no newer than 1984 but none of it is red. The only red I know of is Torco.
EDIT: just as soon as I hit the send button I remembered the RedLine stuff that was red, but it was paste. I never used it, but I know guys that did.
Re: Cam break in lube question [Re: madscientist] #2049814
04/08/16 04:31 PM
04/08/16 04:31 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I use that Redline stuff(paste).. I like it..doesnt
come off easy like most lubes.. as soon as it gets warmed
up it seems to mix in with the oil
wave
Re: Cam break in lube question [Re: cdwmotorsports] #2049890
04/08/16 05:58 PM
04/08/16 05:58 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I also like the Driven engine assembly grease.
Re: Cam break in lube question [Re: cdwmotorsports] #2050001
04/08/16 09:10 PM
04/08/16 09:10 PM
Comp Cams break in lube for cams with non roller lifters is a thick red liquid, it does manage to get all over anything close to it also runaway scopeI wouldn't use it an anything other than the cam lobes and lifter bottoms, not on bearings, rings, wrist pins or valve guides tsk twocents
Re: Cam break in lube question [Re: cdwmotorsports] #2050169
04/09/16 02:32 AM
04/09/16 02:32 AM
Riverside, Ca
R70RUNNER Offline
R70RUNNER  Offline
Riverside, Ca
Like this stuff and the driven grease
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
Re: Cam break in lube question [Re: R70RUNNER] #2050182
04/09/16 03:27 AM
04/09/16 03:27 AM
WI
mopar873 Offline
mopar873  Offline
WI
I have also had very good experiences with the Red Permatex Ultra
Re: Cam break in lube question [Re: cdwmotorsports] #2050368
04/09/16 01:11 PM
04/09/16 01:11 PM
Martinsville, IN
Martinsville, IN
Thanks guys. I bought the Torco Red that Thumperdart suggested yesterday. Amazon has already delivered it this AM.
eBay-cdwmotorsports
Re: Cam break in lube question [Re: cdwmotorsports] #2050421
04/09/16 02:56 PM
04/09/16 02:56 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
That stuff stays where you put it but as suggested, leave the intake off till ready plus you can actually make sure you`re on the base circle while setting valves...............
