Page 4 of 4 1 2 3 4
Re: Stroker cranks available for the 400B block [Re: mopar dave] #2049919
04/08/16 07:00 PM
04/08/16 07:00 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
Originally Posted By mopar dave
correction: I called mahle about the short piston on the street deal and they tell me that it is a myth that you will not get longevity out of a short piston such as their 1.120 pin height.
i wish it was a myth, i bought 2x sets of 1.120ch pistons, both sets suffered from premature wear on the skirts & due to the piston rocking, i had to change rings every year on my race engine just to get the cranking pressure #'s back up.
We learn from our mistakes & I will never run a short piston like this again, they were costing me too much in maintenance. The 1.32ch piston is so much better for long term ring seal. Personally Dave, i think you'd be doing better to build yourself a 512. I've done a couple of 451's with great success, a 470 that was ok but a rod bolt failure cut that motors life short, a 499 stroker was my most expensive to maintain & a 512 which seems to be as good as the 451, but theyre the same piston so not surprised.
Re: Stroker cranks available for the 400B block [Re: rebel] #2049928
04/08/16 07:12 PM
04/08/16 07:12 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
what brand of pistons did you have that issue with? Thanks for the heads up about this possible issue. Mahle told me its the way they build their piston that prevents the worn ring skirt issue. If you want the specifics youll have to give them a call but they told me no issues such as these with their piston.
Re: Stroker cranks available for the 400B block [Re: mopar dave] #2049962
04/08/16 08:01 PM
04/08/16 08:01 PM
Can , Nova Scotia , Cape Breto...
caper Offline
caper  Offline
http://s85.photobucket.com/user/caper_2006/media/HPIM0312.jpg.html?filters[user]=26741373&filters[recent]=1&sort=1&o=1
How do you post a pic? Why does somebody have a site that is very hard to post a pic?
New best 10.18 , 1.40 60 ft 496 Scott Brown built, street driven 3600 lbs,654 hp , 653 ft tq
Re: Stroker cranks available for the 400B block [Re: mopar dave] #2049963
04/08/16 08:01 PM
04/08/16 08:01 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I don't think it is the pin height that allows them to rock in the bore but skirt bottom to piston crown height that keeps the rocking down.
Re: Stroker cranks available for the 400B block [Re: mopar dave] #2049969
04/08/16 08:15 PM
04/08/16 08:15 PM
caper Offline
caper  Offline
HERE IS WHATS ON THE BOX FROM ROSS
bore size 4.375
C.H. 1.865
Ring Groves .0640 .0640 .1880
Ring Lands .220 .155 .080
Pin .990 2.930 DBL
Net Dome CC's -17
Dish Depth .140
INT. V.P> Dia 2.300
Ext V.P. Dia 2.000 depth .300
Net Dia 4.370 depth .260
Total seal rings
Send PM if interested. Going out for evening for a few beers.
Will try to post pics in for sale section tomorrow.
Re: Stroker cranks available for the 400B block [Re: rebel] #2049995
04/08/16 08:59 PM
04/08/16 08:59 PM
On my first 400 block low deck pump gas 4.250 stroke stroker motor I had Ross custom make the pistons with a 22.0 CC dish, they weighed 452 grams without the pins and with the oil ring spacers. I used a forged steel BB Chevy type H beam 6.800 long CAT brand rod and had Ross make the pistons with the tight alloy aluminum to reduce the piston rock in the bores, I don't remeber the exact C.H. but they where real short. I changed the crank to a 4.300 stroke to move the pistons up from .025 down to zero deck when I put the eddy aluminum heads on it two years later to increase the compression ratio. Dram use to call them hockey pucks once I posted a picture of them, the bottom of the skirts would come 1/2 way out of the bores and the pistons skirts look bad,they had visible wear marks from rocking, but measure good thumbs It turns out that alloy is very delicate and mars and marks up easily work shruggy I don't use a compression gauge but the motor did leak down good with a FFA certified aircraft dual gauge leakdown gauge thumbs I put a lot of laps on that motor at the track and drove it on the street some also, probally less than 4000 street miles shruggy
Lots of choices out there, think and check out many things and times before buying, act once thumbs grin
Re: Stroker cranks available for the 400B block [Re: Cab_Burge] #2050002
04/08/16 09:11 PM
04/08/16 09:11 PM
Mt Morris Michigan
Mt Morris Michigan
exactly. I ask on here to get different opinions and that gives me a better idea of which way to go.
Re: Stroker cranks available for the 400B block [Re: caper] #2050004
04/08/16 09:15 PM
04/08/16 09:15 PM
Mt Morris Michigan
Mt Morris Michigan
Go to the botton of the box where to type your reply. Click on file manager.
Re: Stroker cranks available for the 400B block [Re: HotRodDave] #2050056
04/08/16 10:40 PM
04/08/16 10:40 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
I agree. I don't see why wrist pin height factors into overall piston height. It seems to me the max skirt length is determined by stroke, counterweight radius and deck height. I expect the 'hockey puck' pistons are for those who want to brag about their low bob weight.
Re: Stroker cranks available for the 400B block [Re: HotRodDave] #2050075
04/08/16 11:38 PM
04/08/16 11:38 PM
Mt Morris Michigan
Mt Morris Michigan
i Thought the shorter the pin height the shorter the over all piston height as well?
Re: Stroker cranks available for the 400B block [Re: mopar dave] #2050110
04/09/16 12:44 AM
04/09/16 12:44 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
not nessacarily
Re: Stroker cranks available for the 400B block [Re: HotRodDave] #2050132
04/09/16 01:20 AM
04/09/16 01:20 AM
Mt Morris Michigan
Mt Morris Michigan
ok, just seems when i see shorter pin height the piston is lighter as well.
Re: Stroker cranks available for the 400B block [Re: mopar dave] #2050413
04/09/16 02:44 PM
04/09/16 02:44 PM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
I would contact Diamond. They are less than 80 miles from you and will make the piston however you want it. Talk to Ron Beaubien.. I had my custom pistons for one of my builds in less than a week
Re: Stroker cranks available for the 400B block [Re: ccdave] #2050444
04/09/16 03:41 PM
04/09/16 03:41 PM
Mt Morris Michigan
Mt Morris Michigan
ill ask Dwayne Welder about them, he is a dealer for Diamond. He's on 11m and 75.
Re: Stroker cranks available for the 400B block [Re: mopar dave] #2050512
04/09/16 05:47 PM
04/09/16 05:47 PM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
Re: Stroker cranks available for the 400B block [Re: @#$%&*!] #2050639
04/09/16 09:59 PM
04/09/16 09:59 PM
[/quote]
Some of us on here share information based on past expereinces to help others on here make decisions thumbs I order those pistons for a iron headed pump gas motor with those rods and stroke. I hadn't built any other low deck strokers motor from scratch at that time, the pistons are what Ross made for me for that application. When I posted the original dyno results a bunch of the "experts" on here doubted the results without having a clue on what they could do with the same parts, I ended pointed out making 1.19 HP per C.I. on pump gas was no big deal shruggy
If you don't experiment and try new things you will always be behind on the HP curve shruggy Lead, follow or get out of the WAY runaway whistling stirthepot grin
Re: Stroker cranks available for the 400B block [Re: mopar dave] #2050671
04/09/16 10:51 PM
04/09/16 10:51 PM
Riverside, Ca
R70RUNNER Offline
R70RUNNER  Offline
Riverside, Ca
Will offsetting the 4.15 get you into the oil pickup? What's the point of the build? Street? Some strip? What heads? Where I'm going is if you have heads that will only support 500hp maybe a bit more... On a milder build why get into reworking a crank and custom pistons. 451 or 470 would get you there just as easy with less chasing .02
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
Re: Stroker cranks available for the 400B block [Re: R70RUNNER] #2050678
04/09/16 11:03 PM
04/09/16 11:03 PM
Mt Morris Michigan
Mt Morris Michigan
470 was what i wanted to do first. 499/511 costs about the same. I just bought a pickup from source for stroker cranks to fit the pan cab sold me. Mostly street and to track couple times a season. Edelbrock vics cnc flow 359@600 on up. 11-11.5 comp.
Re: Stroker cranks available for the 400B block [Re: mopar dave] #2050755
04/10/16 01:34 AM
04/10/16 01:34 AM
Riverside, Ca
R70RUNNER Offline
R70RUNNER  Offline
Riverside, Ca
Gotcha. My only real thought is build around the heads and theres a lot to be had with your Vic's ... Max it out. I just see 500+" and stealths for street use and it seems odd to use hockey puck pistons on a street build to make 500hp obviously not your direction
Re: Stroker cranks available for the 400B block [Re: R70RUNNER] #2050811
04/10/16 02:32 AM
04/10/16 02:32 AM
Mt Morris Michigan
Mt Morris Michigan
no, the goal is to break into the 9's on pump gas with 3300#. drive most any where.
Page 4 of 4 1 2 3 4
