Re: Stroker cranks available for the 400B block
[Re: mopar dave]
#2049919
04/08/16 07:00 PM
04/08/16 07:00 PM
Posts: 4,648 aotearoa
rebel
aotearoa
correction: I called mahle about the short piston on the street deal and they tell me that it is a myth that you will not get longevity out of a short piston such as their 1.120 pin height. i wish it was a myth, i bought 2x sets of 1.120ch pistons, both sets suffered from premature wear on the skirts & due to the piston rocking, i had to change rings every year on my race engine just to get the cranking pressure #'s back up. We learn from our mistakes & I will never run a short piston like this again, they were costing me too much in maintenance. The 1.32ch piston is so much better for long term ring seal. Personally Dave, i think you'd be doing better to build yourself a 512. I've done a couple of 451's with great success, a 470 that was ok but a rod bolt failure cut that motors life short, a 499 stroker was my most expensive to maintain & a 512 which seems to be as good as the 451, but theyre the same piston so not surprised.
[Re: mopar dave]
#2049963
04/08/16 08:01 PM
04/08/16 08:01 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
I don't think it is the pin height that allows them to rock in the bore but skirt bottom to piston crown height that keeps the rocking down.
[Re: mopar dave]
#2049969
04/08/16 08:15 PM
04/08/16 08:15 PM
Posts: 525 Can , Nova Scotia , Cape Breto...
caper
HERE IS WHATS ON THE BOX FROM ROSS
bore size 4.375 C.H. 1.865 Ring Groves .0640 .0640 .1880 Ring Lands .220 .155 .080 Pin .990 2.930 DBL Net Dome CC's -17 Dish Depth .140 INT. V.P> Dia 2.300 Ext V.P. Dia 2.000 depth .300 Net Dia 4.370 depth .260 Total seal rings Send PM if interested. Going out for evening for a few beers.
Will try to post pics in for sale section tomorrow.
New best 10.18 , 1.40 60 ft 496 Scott Brown built, street driven 3600 lbs,654 hp , 653 ft tq
[Re: rebel]
#2049995
04/08/16 08:59 PM
04/08/16 08:59 PM
Posts: 43,326 Bend,OR USA
Cab_Burge
On my first 400 block low deck pump gas 4.250 stroke stroker motor I had Ross custom make the pistons with a 22.0 CC dish, they weighed 452 grams without the pins and with the oil ring spacers. I used a forged steel BB Chevy type H beam 6.800 long CAT brand rod and had Ross make the pistons with the tight alloy aluminum to reduce the piston rock in the bores, I don't remeber the exact C.H. but they where real short. I changed the crank to a 4.300 stroke to move the pistons up from .025 down to zero deck when I put the eddy aluminum heads on it two years later to increase the compression ratio. Dram use to call them hockey pucks once I posted a picture of them, the bottom of the skirts would come 1/2 way out of the bores and the pistons skirts look bad,they had visible wear marks from rocking, but measure good ![thumbs thumbs](/ubbthreads/images/graemlins/custom/thumbs.gif) It turns out that alloy is very delicate and mars and marks up easily ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) I don't use a compression gauge but the motor did leak down good with a FFA certified aircraft dual gauge leakdown gauge ![thumbs thumbs](/ubbthreads/images/graemlins/custom/thumbs.gif) I put a lot of laps on that motor at the track and drove it on the street some also, probally less than 4000 street miles ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) Lots of choices out there, think and check out many things and times before buying, act once ![grin grin](/ubbthreads/images/graemlins/custom/grin.gif)
[Re: HotRodDave]
#2050056
04/08/16 10:40 PM
04/08/16 10:40 PM
Posts: 1,131 Thigh-Gap Junction
New user name, Same old jerk!
Thigh-Gap Junction
I don't think it is the pin height that allows them to rock in the bore but skirt bottom to piston crown height that keeps the rocking down. I agree. I don't see why wrist pin height factors into overall piston height. It seems to me the max skirt length is determined by stroke, counterweight radius and deck height. I expect the 'hockey puck' pistons are for those who want to brag about their low bob weight.
[Re: @#$%&*!]
#2050639
04/09/16 09:59 PM
04/09/16 09:59 PM
Cab_Burge
I expect the 'hockey puck' pistons are for those who want to brag about their low bob weight. [/quote] Some of us on here share information based on past expereinces to help others on here make decisions ![thumbs thumbs](/ubbthreads/images/graemlins/custom/thumbs.gif) I order those pistons for a iron headed pump gas motor with those rods and stroke. I hadn't built any other low deck strokers motor from scratch at that time, the pistons are what Ross made for me for that application. When I posted the original dyno results a bunch of the "experts" on here doubted the results without having a clue on what they could do with the same parts, I ended pointed out making 1.19 HP per C.I. on pump gas was no big deal ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) If you don't experiment and try new things you will always be behind on the HP curve ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) Lead, follow or get out of the WAY ![grin grin](/ubbthreads/images/graemlins/custom/grin.gif)
[Re: mopar dave]
#2050671
04/09/16 10:51 PM
04/09/16 10:51 PM
Posts: 4,861 Riverside, Ca
R70RUNNER
Riverside, Ca
Will offsetting the 4.15 get you into the oil pickup? What's the point of the build? Street? Some strip? What heads? Where I'm going is if you have heads that will only support 500hp maybe a bit more... On a milder build why get into reworking a crank and custom pistons. 451 or 470 would get you there just as easy with less chasing .02
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
[Re: mopar dave]
#2050755
04/10/16 01:34 AM
04/10/16 01:34 AM
R70RUNNER
Riverside, Ca
Gotcha. My only real thought is build around the heads and theres a lot to be had with your Vic's ... Max it out. I just see 500+" and stealths for street use and it seems odd to use hockey puck pistons on a street build to make 500hp obviously not your direction
