Re: What is the difference between the Drag Pak & Hellcat?
[Re: Dragula]
#2035914
03/21/16 07:22 PM
03/21/16 07:22 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
DP has a 2.9 Whipple blower which is a class rule in fs/xx.
Mopar to the bone!!!
[Re: Dragula]
#2036030
03/21/16 09:52 PM
03/21/16 09:52 PM
72Swinger
Nebraska
I should have been more specific. Just the difference in the blown engines...
Looks like two different supercharger top ends between them...The DP engine says Whipple right on it, but the Hellcat engine looks a bit different.
Can I buy either supercharger setup, and build my own long block? Have not found a Hellcat IHI blower for sale yet, the Hellcat setup is built with 100K mile durability in mind. The DP setup is built with light weight and rules compliance in mind. Here is a breakdown of the Hellcat specs: http://www.hotrod.com/features/1503-inside-the-hellcat-hemi-v8/DP specs I have not found any as far as long block.
[Re: 72Swinger]
#2036130
03/21/16 11:59 PM
03/21/16 11:59 PM
Posts: 12,410 Taxes & Virus's R-US, NY
Dragula
Can I buy either supercharger setup, and build my own long block? Have not found a Hellcat IHI blower for sale yet, the Hellcat setup is built with 100K mile durability in mind. The DP setup is built with light weight and rules compliance in mind. Here is a breakdown of the Hellcat specs: http://www.hotrod.com/features/1503-inside-the-hellcat-hemi-v8/DP specs I have not found any as far as long block. Read thru some of that and the Hellcat blower is 2.4L according to them and the DP is a 2.9L unit....Do we know if the DP unit is intercooled? I suspect not, but figured I would ask.
[Re: Dragula]
#2036358
03/22/16 11:51 AM
03/22/16 11:51 AM
Posts: 46 Ohio
blown71duster
Ohio
[Re: blown71duster]
#2036591
03/22/16 05:15 PM
03/22/16 05:15 PM
Dragula
You know, I called those guys over x-mass I think and they didn't have a bracket that fit one like that! That is way easier to do, I would just need an engine plate sandwiched in there..... I have a 5.7 core down at the shop...I would just need the stroker kit, oil pan, engine plate and super charger and carb.... Thanks for posting that.
