68 b-body window slides #2035143
03/20/16 04:24 PM
03/20/16 04:24 PM
car48nut Offline OP
car48nut  Offline OP
can the plastic window slides still be bought from chrysler, I know they were expensive.
Re: 68 b-body window slides [Re: car48nut] #2035146
03/20/16 04:27 PM
03/20/16 04:27 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
Dixie has them and they're way less
Re: 68 b-body window slides [Re: mikemee1331] #2035154
03/20/16 04:35 PM
03/20/16 04:35 PM
car48nut Offline OP
car48nut  Offline OP
it's been awhile since I worked on my car. could you tell me dixie's web site. thanks. I am still wondering about the shape of my door glass, it has a drop on the back side and I can not find a picture of that glass anywhere
Re: 68 b-body window slides [Re: car48nut] #2035174
03/20/16 05:35 PM
03/20/16 05:35 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
http://www.dixierestorationparts.com/products.cfm?ci=766423BD-04F3-8F65-E6535AA342A6317A
it occurred to me you might be looking for the plastic/nylon pieces that pinch together on either side of the glass and fit into the channel?
Re: 68 b-body window slides [Re: car48nut] #2035197
03/20/16 06:23 PM
03/20/16 06:23 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I've found them for under 50 a side online for original mopar parts... dodge trucks I believe up to the early 90s used the same piece. They also repop them now I think.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: 68 b-body window slides [Re: Silver70] #2035344
03/20/16 10:06 PM
03/20/16 10:06 PM
car48nut Offline OP
car48nut  Offline OP
can anyone help me with the shape of my windows? I tore this car apart 8 years ago. sine then , many things have changed in my life. Lost my wife to cancer and then I just did not want to do anything. I have now decided that I want to get my car going. Can't figure out the window thing. the windows that I have all have a lower piece of glass on the back or front that to repo glass does not have. hope the glass is the right pieces. I can't remember where I got what I have. the original pieces had problems and I think I got different pieces to replace them. Can't remember. thanks the car is a 1968 roadrunner with pop out windows in the back
Re: 68 b-body window slides [Re: car48nut] #2035373
03/20/16 10:29 PM
03/20/16 10:29 PM
Georgia
69bfan Offline
69bfan  Offline
Georgia
The mylar pieces are still available and they retail at close to $73 each from Chrysler. Be very careful in purchasing the cheaper ones on the market as people are passing them off as being original Chrysler pieces. Personally, unless the items are not in the sealed wrap from Chrysler, I would not trust them to being the real deal. The manufacture of the reproductions has redone the tooling and they are much more correct as the first run was too thick and stiff. You can use the reproductions, but make sure that they are of the recent run and be very careful as they are not quite as user friendly as the OEM pieces. Your car is a post car, so these pieces are also used on the rear pop out quarter windows aw well. I stock both styles, so I always point the differences out to my customers.
www.restorationpartsandmaterials.com
Correct Mopar weatherstripping is our specialty, but we stock and supply a wide assortment for all of your restoration needs.
www.dalescudashop.com
Correct style exhaust tips and hardware, fresh air seals, go wings, Cuda & Challenger rear window louvers, hood pin kits
Re: 68 b-body window slides [Re: 69bfan] #2035378
03/20/16 10:42 PM
03/20/16 10:42 PM
car48nut Offline OP
car48nut  Offline OP
what do you recomend for me to use. I am old enough to know that you always get what you pay for' what is your store name?
Re: 68 b-body window slides [Re: car48nut] #2035458
03/21/16 12:07 AM
03/21/16 12:07 AM
Georgia
69bfan Offline
69bfan  Offline
Georgia
I sent you a private message, let me know if you have any questions.
Re: 68 b-body window slides [Re: 69bfan] #2035649
03/21/16 12:27 PM
03/21/16 12:27 PM
car48nut Offline OP
car48nut  Offline OP
I am sorry, but private message did not come to me.
Re: 68 b-body window slides [Re: car48nut] #2035826
03/21/16 04:35 PM
03/21/16 04:35 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I bought some of the reproduction for a customer and they were not near as good as the originals I've used in the past. Buy the OEM ones.
Re: 68 b-body window slides [Re: car48nut] #2036090
03/21/16 11:13 PM
03/21/16 11:13 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
If the parts in this pic are what you want, here are the Chrysler part numbers.
#2932230 is the weatherstrip including the plastic slides/clips.
Slide/clip alone is #4198752.
You can check your local dealer or an online dealer for price and availability. As already mentioned, they are also available from reproduction dealers.
I have not used Chrysler or reproduction ones myself, so cannot comment on either.
beer
Re: 68 b-body window slides [Re: car48nut] #2036116
03/21/16 11:38 PM
03/21/16 11:38 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
I cannot specifically help, but here is some info.
As you probably know, coupe/post door glass is different from hardtop glass. I would first try to determine if the new glass you have is for your car or a hardtop. Do you have any part numbers on the glass or from when you bought it?
Chrysler lists different part# glass for '68 compared to '69/70. However the reproduction/aftermarket glass suppliers list the same glass for '68-70 (coupes and hardtops being different). So, perhaps the replacement glass will work.
Hopefully someone with more knowledge of '68 door glass will help you out.
Here is a thread with a photo of '68 post style glass that sounds like you describe.
https://board.moparts.org/ubbthreads/ubbt...terchanges.html
Here are more threads discussing door glass.
https://board.moparts.org/ubbthreads/ubbt...door-glass.html
https://board.moparts.org/ubbthreads/ubbthreads.php/topics/1551534/re-68-gtx-door-glass.html
https://board.moparts.org/ubbthreads/ubbt...-shattered.html
https://board.moparts.org/ubbthreads/ubbthreads.php/topics/146590/re-door-glass-swap.html
beer
