Crane gold rockers #2031177
03/14/16 09:11 PM
03/14/16 09:11 PM
Mt.Vernon ,Ohio
VernMotor Offline OP
Mt.Vernon ,Ohio
I see a set that does not have needle bearing that ride on the shaft.don't look like they even have a bushing in them. anyone run these ? good- bad ?
Re: Crane gold rockers [Re: VernMotor] #2031194
03/14/16 09:46 PM
03/14/16 09:46 PM
Ambridge, Pa.
rickraw Online content
rickraw  Online Content
Ambridge, Pa.
I ran them yrs ago, 493 stroker. Never had a problem
Re: Crane gold rockers [Re: rickraw] #2031201
03/14/16 09:53 PM
03/14/16 09:53 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
The old Cranes were just aluminium with no rollers or bushings. I ran them on my W2 heads and ran 9's with them on but I only had a .520 lift Racer Brown solid lift cam. I did put some banana grooves on my shafts to help with oiling. They worked very good.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Crane gold rockers [Re: VernMotor] #2031219
03/14/16 10:24 PM
03/14/16 10:24 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I cannot speak to the new stuff, but the Crane "golds" have been around forever, and we're once considered the standard for anything up to solid roller cam level stuff. Some have had luck with them in that application too, if not too wild.
I've have a set probably 20 years now, but pretty light duty solid and hyd FT stuff.
Re: Crane gold rockers [Re: BSB67] #2031225
03/14/16 10:28 PM
03/14/16 10:28 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Still a great low-buck rocker imo. I bought a set from crane a year or so ago, took a month or two for them to get me a complete w2 set up, but they did, shipped at different intervals. Might be up to speed now, as they were restarting at the time I ordered IIRC.
Re: Crane gold rockers [Re: VernMotor] #2031232
03/14/16 10:39 PM
03/14/16 10:39 PM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
They be ok with a .620 lift solid cam ?
Re: Crane gold rockers [Re: VernMotor] #2031243
03/14/16 10:50 PM
03/14/16 10:50 PM
Way out in the sticks of Weste...
DusterDog Offline
DusterDog  Offline
I ran a set on a 440 in my bracket Cuda with a 654 lift mushroom tappet MP camshaft, NO problems.
Heck, I still have them on my next 440 bracket motor that's on my engine stand, ready to go on my buddy's fire-up stand.
"I've upped my horsepower, so...... UP YOURS!!!"
Re: Crane gold rockers [Re: VernMotor] #2031298
03/14/16 11:43 PM
03/14/16 11:43 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Jamie... you are talking the ones with the roller tip..
correct.... Crane made them for the MP blue rockers...
with the roller tip FT cam at .620 you will be fine..
I ran them on my SB at .640 lift
wave
Re: Crane gold rockers [Re: VernMotor] #2031338
03/15/16 12:26 AM
03/15/16 12:26 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Been running several sets of them on flat tappet cams for years..
using 1.6 rocker on hughes cam with gross lift of .651....and two other cars with lifts in the .640 range..
have run them on w2 engines also...in fact I just bought 4 1.6 w2 rockers...2 left and 2 rights for back up ...ordered them from Jegs..shipped directly from Crane..
Tony
70 AARCuda Vitamin C
Re: Crane gold rockers [Re: VernMotor] #2031355
03/15/16 12:44 AM
03/15/16 12:44 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Only thing I used for years. W-2s, solid roller, 7400-7800RPM on the same set. Never hurt them. Only after restricting the oil to the heads did they begin to show any wear. I didn't run a ton of spring pressure, but still...
Re: Crane gold rockers [Re: VernMotor] #2031380
03/15/16 01:07 AM
03/15/16 01:07 AM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
I have broken one Crane Gold but still like them, had them on this 528 with a 720 lift solid all good, they are now semi retired on my sons 440 steet strip Valiant.
PS I would never run another set of roller rockers with needle bearings again, ever.
1963 Plymouth Max Wedge
1971 Barracuda
Re: Crane gold rockers [Re: ozymaxwedge] #2031468
03/15/16 04:43 AM
03/15/16 04:43 AM
Oh
His and Her 69's Offline
Oh
I have had them on Janet's RR since 2004 and still working Good.
I had 2 last year that the roller pin was working its way out.
I just went and bought 2 new ones to replace them. I swedged the 1 and am using it for a spare. They are on a 557 solid cam now and was on a 615 lift solid cam before that.
I would run them again without and hesitation.
David
Re: Crane gold rockers [Re: VernMotor] #2031532
03/15/16 10:54 AM
03/15/16 10:54 AM
MD
JACK1440 Offline
JACK1440  Offline
MD
I personally like them. Been running them for years without problem. .750 lift roller @ 7000 rpm all day. They aren't the nice roller fulcrum but, I think good for the price. They have been hard to get for about a year though.
Re: Crane gold rockers [Re: VernMotor] #2031572
03/15/16 11:44 AM
03/15/16 11:44 AM
Mt.Vernon ,Ohio
Mt.Vernon ,Ohio
Guy had them on line. I got pictures didn't look right to me. Got the part numbers from him found out they was for a small block.. I need big block. He did't know..
Re: Crane gold rockers [Re: VernMotor] #2031623
03/15/16 01:23 PM
03/15/16 01:23 PM
Queens, New York
Harley Offline
Harley  Offline
Queens, New York
I have a set on my motor going back to 1996. .613 lift 278@.050 with no problems.
Re: Crane gold rockers [Re: Harley] #2031668
03/15/16 02:33 PM
03/15/16 02:33 PM
dogdays Offline
dogdays  Offline
"They aren't the nice roller fulcrum"
That's a plus. Roller or needle bearings are a needless complication, plus they reduce the strength of the rocker body. Plain bearings also deal with impact loads better than rolling element bearings.
R.
