Re: Crane gold rockers
[Re: rickraw]
#2031201
03/14/16 09:53 PM
03/14/16 09:53 PM
Posts: 20,189 PA.
pittsburghracer
"Little"John
"Little"John
PA.
The old Cranes were just aluminium with no rollers or bushings. I ran them on my W2 heads and ran 9's with them on but I only had a .520 lift Racer Brown solid lift cam. I did put some banana grooves on my shafts to help with oiling. They worked very good.
[Re: VernMotor]
#2031243
03/14/16 10:50 PM
03/14/16 10:50 PM
Posts: 1,269 Way out in the sticks of Weste...
DusterDog
I ran a set on a 440 in my bracket Cuda with a 654 lift mushroom tappet MP camshaft, NO problems.
Heck, I still have them on my next 440 bracket motor that's on my engine stand, ready to go on my buddy's fire-up stand.
"I've upped my horsepower, so...... UP YOURS!!!"
[Re: VernMotor]
#2031298
03/14/16 11:43 PM
03/14/16 11:43 PM
Posts: 52,972 Romeo MI
MR_P_BODY
They be ok with a .620 lift solid cam ? Jamie... you are talking the ones with the roller tip.. correct.... Crane made them for the MP blue rockers... with the roller tip FT cam at .620 you will be fine.. I ran them on my SB at .640 lift
[Re: VernMotor]
#2031338
03/15/16 12:26 AM
03/15/16 12:26 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
Been running several sets of them on flat tappet cams for years..
using 1.6 rocker on hughes cam with gross lift of .651....and two other cars with lifts in the .640 range..
have run them on w2 engines also...in fact I just bought 4 1.6 w2 rockers...2 left and 2 rights for back up ...ordered them from Jegs..shipped directly from Crane..
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: VernMotor]
#2031355
03/15/16 12:44 AM
03/15/16 12:44 AM
Posts: 11,638 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Only thing I used for years. W-2s, solid roller, 7400-7800RPM on the same set. Never hurt them. Only after restricting the oil to the heads did they begin to show any wear. I didn't run a ton of spring pressure, but still...
[Re: VernMotor]
#2031380
03/15/16 01:07 AM
03/15/16 01:07 AM
Posts: 1,096 Australia
ozymaxwedge
Australia
I have broken one Crane Gold but still like them, had them on this 528 with a 720 lift solid all good, they are now semi retired on my sons 440 steet strip Valiant. PS I would never run another set of roller rockers with needle bearings again, ever.
1963 Plymouth Max Wedge 1971 Barracuda
