New engine break-in? #202524
01/24/09 12:14 AM
01/24/09 12:14 AM
Springfield TN
RedRamQC Offline OP
RedRamQC  Offline OP
Springfield TN
I just had a new engine put in my Ram. The dealer service dept. said no break in is necessary, just change the oil at 3000 miles. My buddy at work insists I change the oil at 150 miles. What do you all think?
Re: New engine break-in? [Re: RedRamQC] #202525
01/24/09 12:30 AM
01/24/09 12:30 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Drive it. Depending on the build it may have anti friction and scuffing additives in the oil and its better to leave them in to do their job.
Re: New engine break-in? [Re: NITROUSN] #202526
01/24/09 11:21 PM
01/24/09 11:21 PM
ky.
K
kenworth_goose Offline
K
ky.
Load it like a box car, drive it like a stock car. Or like you stole it.
Re: New engine break-in? [Re: kenworth_goose] #202527
01/25/09 12:05 AM
01/25/09 12:05 AM
Change it. That's a time when an eng needs frequent fluid changes imnho. fresh additives/flushes contaminates, you sleep better at night cause your taking care of things right & you get to spend money
Re: New engine break-in? [Re: RapidRobert] #202528
01/25/09 01:17 AM
01/25/09 01:17 AM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
After a week of driving just recheck your fluid levels. Change your oil in 3k. What happen to the first engine?
Re: New engine break-in? [Re: SALEM1912] #202529
01/25/09 09:04 AM
01/25/09 09:04 AM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
If it were mine I would change that oil very early to get the metal from the break in out of the engine.
Re: New engine break-in? [Re: 69Cuda340S] #202530
01/25/09 03:44 PM
01/25/09 03:44 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Thats what you have filters for. Plus if there is metal floating around in a new motor there is a problem. All new cars are driven with a new motor there is no difference from reman to new. In some cases the reman may be cleaner.It all has to do with the assembler and if he is particular on cleanliness.
Re: New engine break-in? [Re: NITROUSN] #202531
01/25/09 03:47 PM
01/25/09 03:47 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
No breakin needed or early oil changes. Oil changes are over rated. Lot's of motor oil wasted over the years.
Re: New engine break-in? [Re: 69Cuda340S] #202532
01/25/09 03:49 PM
01/25/09 03:49 PM
Bridgeport, WV
Michael Offline
Michael  Offline
Bridgeport, WV
Re: New engine break-in? [Re: Michael] #202533
01/25/09 09:27 PM
01/25/09 09:27 PM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
+1
It's Swifty! Swifty, you toad sucker!
Re: New engine break-in? [Re: zrxkawboy] #202534
01/25/09 09:45 PM
01/25/09 09:45 PM
MNobody Offline
MNobody  Offline
I've had 2 Ram's and was told to leave the oil in for 3000 miles.
Re: New engine break-in? [Re: MNobody] #202535
01/25/09 10:02 PM
01/25/09 10:02 PM
Springfield TN
RedRamQC Offline OP
RedRamQC  Offline OP
Springfield TN
Well I picked it up Friday afternoon, have put about 90 miles on it this weekend. Checked the oil when I got home this afternoon and it was below the add line. No oil spots on the driveway either. Guess I'm calling the service dept. in the morning.
Re: New engine break-in? [Re: RedRamQC] #202536
01/25/09 10:38 PM
01/25/09 10:38 PM
MNobody Offline
MNobody  Offline
Was it full when you got it?
Re: New engine break-in? [Re: MNobody] #202537
01/25/09 10:43 PM
01/25/09 10:43 PM
Springfield TN
RedRamQC Offline OP
RedRamQC  Offline OP
Springfield TN
Umm..well I didn't check. I would have assumed it was. Would they really have replaced an engine under warranty and not put enough oil in it?
Re: New engine break-in? [Re: RedRamQC] #202538
01/25/09 10:52 PM
01/25/09 10:52 PM
MNobody Offline
MNobody  Offline
Stranger things have happened...I would think it would be smokin pretty bad to burn over a quart of oil in 90 miles.
Re: New engine break-in? [Re: MNobody] #202539
01/25/09 11:17 PM
01/25/09 11:17 PM
Central NC
gch Offline
gch  Offline
Central NC
On a new engine or after a cam swap I will drive the engine long enough to get it hot several times and then change the oil and filter.Then I resume normal intervals.Piece of mind goes a long way.
I would document this with the service dept to aid in any future warranty considerations should you have a problem.
Re: New engine break-in? [Re: gch] #202540
01/26/09 04:47 AM
01/26/09 04:47 AM
wisconsin
72dak Offline
72dak  Offline
wisconsin
one thing you should do for sure is reduce idle time to a minimum. ive seen 2 engines burn oil really bad because of ecxessive idling after a fresh rebuild
Re: New engine break-in? [Re: MNobody] #202541
01/29/09 03:25 AM
01/29/09 03:25 AM
Springfield TN
RedRamQC Offline OP
RedRamQC  Offline OP
Springfield TN
Well I took it back in Monday morning just so they could confirm it was low and to top it back off. The service advisor assured me that they put 6 quarts in, but according to my itemized bill, they only put in 5 No problems since.
Re: New engine break-in? [Re: RedRamQC] #202542
01/29/09 10:01 AM
01/29/09 10:01 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
If your engine is a service replacement,the breakin would be the same as when your truck was new.If so,read your owners manual.
