Re: New engine break-in?
[Re: kenworth_goose]
#202527
01/25/09 12:05 AM
01/25/09 12:05 AM
RapidRobert
Change it. That's a time when an eng needs frequent fluid changes imnho. fresh additives/flushes contaminates, you sleep better at night cause your taking care of things right & you get to spend money
[Re: 69Cuda340S]
#202530
01/25/09 03:44 PM
01/25/09 03:44 PM
Posts: 18,425 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
If it were mine I would change that oil very early to get the metal from the break in out of the engine.
Thats what you have filters for. Plus if there is metal floating around in a new motor there is a problem. All new cars are driven with a new motor there is no difference from reman to new. In some cases the reman may be cleaner.It all has to do with the assembler and if he is particular on cleanliness.
[Re: NITROUSN]
#202531
01/25/09 03:47 PM
01/25/09 03:47 PM
Challenger 1
Cincinnati, Ohio
No breakin needed or early oil changes. Oil changes are over rated. Lot's of motor oil wasted over the years.
[Re: 69Cuda340S]
#202532
01/25/09 03:49 PM
01/25/09 03:49 PM
Posts: 6,183 Bridgeport, WV
Michael
Bridgeport, WV
[Re: MNobody]
#202537
01/25/09 10:43 PM
01/25/09 10:43 PM
Posts: 1,083 Springfield TN
RedRamQC
Springfield TN
Was it full when you got it?
Umm..well I didn't check. I would have assumed it was. Would they really have replaced an engine under warranty and not put enough oil in it?
[Re: RedRamQC]
#202538
01/25/09 10:52 PM
01/25/09 10:52 PM
Posts: 4,884 Michigan
MNobody
Stranger things have happened...I would think it would be smokin pretty bad to burn over a quart of oil in 90 miles.
[Re: MNobody]
#202541
01/29/09 03:25 AM
01/29/09 03:25 AM
RedRamQC
Springfield TN
Well I took it back in Monday morning just so they could confirm it was low and to top it back off. The service advisor assured me that they put 6 quarts in, but according to my itemized bill, they only put in 5 No problems since.
