Anyone running a Bill Mitchell 440 wedge Aluminum block??
#2016320
02/20/16 10:33 PM
02/20/16 10:33 PM
Posts: 1,646 Ringtown, Pa.
Dartsport540
Ringtown, Pa.
Any one running a Bill Mitchell 440 wedge Aluminum block?? I am thinking about getting one. http://www.theengineshop.com/products/en...inum-block.html I had my second stock block crack. They both lasted 5 years. Both were a 505 cu. in. Callis crank, oliver rods, B1 heads. Around 750 horse power.
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
Re: Anyone running a Bill Mitchell 440 wedge Aluminum block??
[Re: Dragula]
#2016632
02/21/16 04:03 PM
02/21/16 04:03 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
Call and ask if they drilled the head deck holes into the water jackets... According to the text........ " Cylinder Head Holes: Blind tapped to prevent leaks 1.400" thread depth " I'd say nope.
[Re: tubtar]
#2016640
02/21/16 04:19 PM
02/21/16 04:19 PM
Posts: 12,404 Taxes & Virus's R-US, NY
Dragula
Call and ask if they drilled the head deck holes into the water jackets... According to the text........ " Cylinder Head Holes: Blind tapped to prevent leaks 1.400" thread depth " I'd say nope. I had a World Block, not aluminum mind you, and they were drilled into the water jacket and there is no reason to...What a mess. Called them, and they are worse than Indy for customer service. No thanks, never again. Oooh wait, it says they aren't drilled thru on the internet.... Every after market block has issues. Some are easy fixes, some are not. Customer service then comes into play, and they are horrible.
[Re: Dragula]
#2016724
02/21/16 06:19 PM
02/21/16 06:19 PM
Posts: 289 Lowes
steve660
Lowes
Call and ask if they drilled the head deck holes into the water jackets... According to the text........ " Cylinder Head Holes: Blind tapped to prevent leaks 1.400" thread depth " I'd say nope. I had a World Block, not aluminum mind you, and they were drilled into the water jacket and there is no reason to...What a mess. Called them, and they are worse than Indy for customer service. No thanks, never again. Oooh wait, it says they aren't drilled thru on the internet.... Every after market block has issues. Some are easy fixes, some are not. Customer service then comes into play, and they are horrible. Bill Mitchell customer service blows. Have a iron world wedge block with paper thin cracks in webbing above mains on drivers side. I contacted Bill Mitchell and was told they have NEVER had a casting flaw / blem issue. And if there was a bad block it would have been scraped. I ground out paper thin webbing until I found solid material. Still it was only .040ish thick. Now I have 3 quarter size windows on drivers side above mains. Looks like a LS block with bay to bay breathing!!
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure. ..... Now its a door stop....
[Re: Lancer273cid]
#2828138
10/02/20 11:34 PM
10/02/20 11:34 PM
Posts: 326 Alberta
Wookie316
Alberta
I have an old world block that I’m building a 572 out of. It needed lots of machining work to make right. Would of had in the car this year but bam, COVID takes over. Hope to finish it this winter. It will be a bracket motor for my Charger. At the power level it should make, probably a high 9.70’s to low 9.80’s car on kill. Since cage is only good to 10.0, will tune down so it runs 10.0’s to 10.teens.
Hope once it is together it holds up well. Will be nice to get that weight off the nose too being an aluminum block.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
