Anyone running a Bill Mitchell 440 wedge Aluminum block?? #2016320
02/20/16 10:33 PM
02/20/16 10:33 PM
Ringtown, Pa.
Dartsport540 Offline OP
Ringtown, Pa.
Any one running a Bill Mitchell 440 wedge Aluminum block?? I am thinking about getting one.
http://www.theengineshop.com/products/en...inum-block.html
I had my second stock block crack. They both lasted 5 years. Both were a 505 cu. in. Callis crank, oliver rods, B1 heads. Around 750 horse power.
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
Re: Anyone running a Bill Mitchell 440 wedge Aluminum block?? [Re: Dartsport540] #2016364
02/21/16 12:05 AM
02/21/16 12:05 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Call and ask if they drilled the head deck holes into the water jackets...
Re: Anyone running a Bill Mitchell 440 wedge Aluminum block?? [Re: Dragula] #2016396
02/21/16 12:42 AM
02/21/16 12:42 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
They are World Products blocks.
Re: Anyone running a Bill Mitchell 440 wedge Aluminum block?? [Re: Dragula] #2016632
02/21/16 04:03 PM
02/21/16 04:03 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
According to the text........
" Cylinder Head Holes: Blind tapped to prevent leaks 1.400" thread depth "
I'd say nope.
Re: Anyone running a Bill Mitchell 440 wedge Aluminum block?? [Re: tubtar] #2016640
02/21/16 04:19 PM
02/21/16 04:19 PM
Dragula Offline
Dragula  Offline
I'd say nope.
I had a World Block, not aluminum mind you, and they were drilled into the water jacket and there is no reason to...What a mess. Called them, and they are worse than Indy for customer service. No thanks, never again. Oooh wait, it says they aren't drilled thru on the internet....
Every after market block has issues. Some are easy fixes, some are not. Customer service then comes into play, and they are horrible.
Re: Anyone running a Bill Mitchell 440 wedge Aluminum block?? [Re: Dragula] #2016724
02/21/16 06:19 PM
02/21/16 06:19 PM
Lowes
steve660 Offline
steve660  Offline
Lowes
I'd say nope.
Bill Mitchell customer service blows.
Have a iron world wedge block with paper thin cracks in webbing above mains on drivers side.
I contacted Bill Mitchell and was told they have NEVER had a casting flaw / blem issue. And if there was a bad block it would have been scraped.
I ground out paper thin webbing until I found solid material. Still it was only .040ish thick.
Now I have 3 quarter size windows on drivers side above mains.
Looks like a LS block with bay to bay breathing!!
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure.
..... Now its a door stop....
Re: Anyone running a Bill Mitchell 440 wedge Aluminum block?? [Re: Dartsport540] #2016907
02/21/16 10:31 PM
02/21/16 10:31 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
Wait till you unbolt the main caps and they fall out
Re: Anyone running a Bill Mitchell 440 wedge Aluminum block?? [Re: Dartsport540] #2017283
02/22/16 11:49 AM
02/22/16 11:49 AM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
I have been running one for 7 years. Never had any problems with it. It has been freshened twice. Bearings look like brand new when I take it apart. 4.150 crank and 4.440 bore the last time. Runs 9.60's 140mph. I had to hone the lifter bores when I got it and bore the cylinders to correct size, everything else was OK to run.
Re: Anyone running a Bill Mitchell 440 wedge Aluminum block?? [Re: jwb123] #2827829
10/02/20 11:49 AM
10/02/20 11:49 AM
Finland
Lancer273cid Offline
Finland
Any quality problems on blocks delivered in 2020? Considering of getting one for the future build, since these should be available right now, who knows if there is any aftermarket blocks available in a couple years from now..
Re: Anyone running a Bill Mitchell 440 wedge Aluminum block?? [Re: Lancer273cid] #2828138
10/02/20 11:34 PM
10/02/20 11:34 PM
Alberta
Wookie316 Offline
Wookie316  Offline
Alberta
I have an old world block that I’m building a 572 out of.
It needed lots of machining work to make right.
Would of had in the car this year but bam, COVID takes over.
Hope to finish it this winter.
It will be a bracket motor for my Charger.
At the power level it should make, probably a high 9.70’s to low 9.80’s car on kill.
Since cage is only good to 10.0, will tune down so it runs 10.0’s to 10.teens.
Hope once it is together it holds up well.
Will be nice to get that weight off the nose too being an aluminum block.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
