Re: Low Deck Hemi
[Re: Dragula]
#2008837
02/09/16 10:11 PM
02/09/16 10:11 PM
Posts: 1,361 Wild West
M_D
Wild West
I'm not aware of any Hemi low deck blocks and intakes, were there ever any made?
Re: Low Deck Hemi
[Re: Dragula]
#2008852
02/09/16 10:25 PM
02/09/16 10:25 PM
Posts: 7,495 Minnesota
Hemi_Joel
Minnesota
John Hagen had a low deck Hemi in his pro stock arrow. (The car killed him, unfortunately) It was a 383 block with the bosses for the intake port head studs welded onto the block.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
Re: Low Deck Hemi
[Re: LSP]
#2009548
02/10/16 10:58 PM
02/10/16 10:58 PM
Posts: 2,175 Duloc
The Shadow
Duloc
Before NHRA went to the 500" format in pro stock, Gen 2 hemi heads on a 383 block at 387-390 ci went faster than anything else at the time. Stage V used to offer a head that would bolt right on a wedge pattern block, not sure if any of that stuff is still around. FHO just had a new set come in from stage v that he was cnc porting
Re: Low Deck Hemi
[Re: Dragula]
#2010037
02/11/16 07:30 PM
02/11/16 07:30 PM
Hemi_Joel
Minnesota
Charlie has the same degree wheel that I do!
Re: Low Deck Hemi
[Re: Dragula]
#2010115
02/11/16 09:10 PM
02/11/16 09:10 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Whats the advantage of a low deck? stiffness?
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
Re: Low Deck Hemi
[Re: Dragula]
#2010187
02/11/16 11:03 PM
02/11/16 11:03 PM
Posts: 1,314 Charlotte, NC
LSP
Charlotte, NC
Those are some cool old pics KDY!
Even at the B deck they were still too tall, but better. Shorter pistons are lighter, shorter pushrods are stiffer, etc., another inch shorter deck would have been a nice package.
I know a guy that worked on a 370" BBC pro stock deal that had the entire deck removed, the block shortened, then the deck surface furnace brazed back on. Crazy stuff, but if you couldn't find what you wanted, you made it yourself.
