Page 1 of 3 1 2 3
Low Deck Hemi #2008832
02/09/16 09:58 PM
02/09/16 09:58 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
Anyone ever do one? Alum block 400 sized bearings etc....
Re: Low Deck Hemi [Re: Dragula] #2008837
02/09/16 10:11 PM
02/09/16 10:11 PM
Wild West
M_D Offline
M_D  Offline
Wild West
I'm not aware of any Hemi low deck blocks and intakes, were there ever any made?
Re: Low Deck Hemi [Re: M_D] #2008842
02/09/16 10:19 PM
02/09/16 10:19 PM
Dragula Offline OP
Dragula  Offline OP
You can order one thru Indy....I know they made one a while back...
Re: Low Deck Hemi [Re: Dragula] #2008852
02/09/16 10:25 PM
02/09/16 10:25 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
John Hagen had a low deck Hemi in his pro stock arrow. (The car killed him, unfortunately) It was a 383 block with the bosses for the intake port head studs welded onto the block.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Low Deck Hemi [Re: Dragula] #2008853
02/09/16 10:26 PM
02/09/16 10:26 PM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
Before NHRA went to the 500" format in pro stock, Gen 2 hemi heads on a 383 block at 387-390 ci went faster than anything else at the time. Stage V used to offer a head that would bolt right on a wedge pattern block, not sure if any of that stuff is still around.
Re: Low Deck Hemi [Re: Dragula] #2008855
02/09/16 10:29 PM
02/09/16 10:29 PM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
Hemi Joel beat me to it, John was actually killed in his new Charger/Omni with a 500" motor under the hood. The Arrow was restored and on display at Indy last year.
Re: Low Deck Hemi [Re: LSP] #2008915
02/09/16 11:36 PM
02/09/16 11:36 PM
illinois
E
evenflow Offline
evenflow  Offline
E
illinois
Tom Haner used to have one in a 4 speed barracuda years ago in the chicago area. I think his was a 400 block welded high revving 7400+ shifts.
Re: Low Deck Hemi [Re: Dragula] #2008988
02/10/16 01:00 AM
02/10/16 01:00 AM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
Yes, Tom Haner bought all of Hagen's small hemis after the rule change, and ran them in the ex-Lambeck 68 Barracuda. Tom stopped in at the engine shop I was working at back in the early 90's, he shared some info on what made the 383 based hemis tick, and did also mention that he flat footed them on the line at 9400 (no rev limiter) and shifted at 9000.
Re: Low Deck Hemi [Re: Dragula] #2009042
02/10/16 02:10 AM
02/10/16 02:10 AM
indiana
ss/ah3480 Offline
ss/ah3480  Offline
indiana
Superstock hemis are closer to b deck height than rb
Re: Low Deck Hemi [Re: ss/ah3480] #2009076
02/10/16 04:22 AM
02/10/16 04:22 AM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Lol...I was thinking the same thing.
Re: Low Deck Hemi [Re: ss/ah3480] #2009175
02/10/16 12:57 PM
02/10/16 12:57 PM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
They're being cut that much?
72 Plymouth Roadrunner 11.08@123.25
Re: Low Deck Hemi [Re: Dragula] #2009206
02/10/16 01:44 PM
02/10/16 01:44 PM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
LSM cut the one I had to 10.200"
Re: Low Deck Hemi [Re: Dragula] #2009266
02/10/16 03:16 PM
02/10/16 03:16 PM
Roughbird72 Offline
Roughbird72  Offline
Wow, .525 seems like a lot to me.
Re: Low Deck Hemi [Re: LSP] #2009548
02/10/16 10:58 PM
02/10/16 10:58 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
FHO just had a new set come in from stage v that he was cnc porting
Re: Low Deck Hemi [Re: Dragula] #2009940
02/11/16 05:01 PM
02/11/16 05:01 PM
dogdays Offline
dogdays  Offline
FWIW, the Ball-stud Hemi was built on a B-height block.
R.
Re: Low Deck Hemi [Re: Dragula] #2009978
02/11/16 06:05 PM
02/11/16 06:05 PM
Chattanooga, TN
KDY Offline
KDY  Offline
Chattanooga, TN
Charlie Malyuke's
Re: Low Deck Hemi [Re: Dragula] #2010037
02/11/16 07:30 PM
02/11/16 07:30 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Charlie has the same degree wheel that I do!
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Low Deck Hemi [Re: Dragula] #2010115
02/11/16 09:10 PM
02/11/16 09:10 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Whats the advantage of a low deck? stiffness?
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Low Deck Hemi [Re: Dragula] #2010187
02/11/16 11:03 PM
02/11/16 11:03 PM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
Those are some cool old pics KDY!
Even at the B deck they were still too tall, but better. Shorter pistons are lighter, shorter pushrods are stiffer, etc., another inch shorter deck would have been a nice package.
I know a guy that worked on a 370" BBC pro stock deal that had the entire deck removed, the block shortened, then the deck surface furnace brazed back on. Crazy stuff, but if you couldn't find what you wanted, you made it yourself.
Re: Low Deck Hemi [Re: LSP] #2010226
02/12/16 12:04 AM
02/12/16 12:04 AM
illinois
E
evenflow Offline
evenflow  Offline
E
illinois
I know of one brazed block floating around that has had .300 taken off the deck. Mike Radnis used to run that set up in one of his old cars. Not sure if he is a member.
Page 1 of 3 1 2 3
