aftermarket Powerglide bellhousing question? #2004663
02/03/16 06:26 AM
02/03/16 06:26 AM
Melbourne , Australia
LA360 Offline OP
LA360  Offline OP
The Reid, BTE and ATI Powerglide bell housings, do they all have the same bolt pattern? I'm referring to the bolt pattern that mates the bell housing to the transmission case.
Cheers
Alan Jones
Re: aftermarket Powerglide bellhousing question? [Re: LA360] #2004672
02/03/16 08:44 AM
02/03/16 08:44 AM
michigan
turbo toad Offline
turbo toad  Offline
michigan
They use the thru bolts for the front pump assembly on the glide to mate the bell to the trans. So i would say yes they do all have the same bolt pattern.
Im in the process of test fitting my valiant for a glide now, and I have to figure out what im going to do about the trans cross member.
Check out my build on Facebook Ttoad Hurley its updated regularly
Re: aftermarket Powerglide bellhousing question? [Re: turbo toad] #2004688
02/03/16 10:11 AM
02/03/16 10:11 AM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
i use a jw on mine and a 6 cld glide ,i think the reid will only bolt to a read case , trany mount all i done is weld a 2 inch plate to the mount and bolts up fine with the std xross member
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: aftermarket Powerglide bellhousing question? [Re: turbo toad] #2004696
02/03/16 10:50 AM
02/03/16 10:50 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Incorrect.........JW is the ONLY one that uses the front pump bell bolts. Reid and ATI both use a flange on the case that the bell bolts to and they are NOT the same pattern between the two
Re: aftermarket Powerglide bellhousing question? [Re: LA360] #2004700
02/03/16 11:00 AM
02/03/16 11:00 AM
Blue Ridge, VA
Plumb Wired Offline
Plumb Wired  Offline
Blue Ridge, VA
JW bell mounts with the pump bolts. Reid, BTE & ATI the bell mounts to the transmission case, I don't know if the bells from one company will bolt to the case of another.
RIP Monte Smith
aka: OutlawFish
'98 Bickel Dodge Dakota PST
Re: aftermarket Powerglide bellhousing question? [Re: LA360] #2004717
02/03/16 11:37 AM
02/03/16 11:37 AM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
Reid and BTE are the same. ATI is it's own and JW bolts to the pump.
Without Data, you’re just another guy with an opinion.
Re: aftermarket Powerglide bellhousing question? [Re: Ian] #2004773
02/03/16 01:22 PM
02/03/16 01:22 PM
michigan
turbo toad Offline
turbo toad  Offline
michigan
Thanks Monte i stand corrected im using a JW ultrabell and thought they all bolted up the same way
[quote=Ian, trany mount all i done is weld a 2 inch plate to the mount and bolts up fine with the std xross member[/quote]
Ian do you happen to have any pics of your trans cross member
Re: aftermarket Powerglide bellhousing question? [Re: sr4440] #2004797
02/03/16 02:09 PM
02/03/16 02:09 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
This is correct......but I think BTE likely buys their bells from Reid.
The JW would be my last choice for a Glide, if I was starting from scratch. Not a huge fan of the bell mounting to the pump bolts
Re: aftermarket Powerglide bellhousing question? [Re: Monte_Smith] #2004859
02/03/16 03:28 PM
02/03/16 03:28 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Agreed. I've used the JW deal on a stock case. Have to pay attention to sealing the bolts to avoid leaks. Only reason/advantage to use JW's set up is the ability to use a stock case.
Re: aftermarket Powerglide bellhousing question? [Re: CMcAllister] #2004879
02/03/16 03:48 PM
02/03/16 03:48 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
BTE has their own Chevy bells. They sell Reid for others. ATI is its own pattern. ATI turbo 400 customers can request the register machined down as they include the Reid pattern.
Quicktime also offers a few steel bells that use Reid pattern that are a higher still cert.
Re: aftermarket Powerglide bellhousing question? [Re: turbo toad] #2004900
02/03/16 04:21 PM
02/03/16 04:21 PM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
[quote=turbo toad]They use the thru bolts for the front pump assembly on the glide to mate the bell to the trans. So i would say yes they do all have the same bolt pattern.
Originally Posted By Ian, trany mount all i done is weld a 2 inch plate to the mount and bolts up fine with the std xross member[/quote
i will get a pic later today for you
