aftermarket Powerglide bellhousing question?
#2004663
02/03/16 06:26 AM
02/03/16 06:26 AM
Posts: 6,136 Melbourne , Australia
LA360
The Reid, BTE and ATI Powerglide bell housings, do they all have the same bolt pattern? I'm referring to the bolt pattern that mates the bell housing to the transmission case.
Cheers
Alan Jones
Re: aftermarket Powerglide bellhousing question?
[Re: LA360]
#2004672
02/03/16 08:44 AM
02/03/16 08:44 AM
Posts: 368 michigan
turbo toad
michigan
They use the thru bolts for the front pump assembly on the glide to mate the bell to the trans. So i would say yes they do all have the same bolt pattern. Im in the process of test fitting my valiant for a glide now, and I have to figure out what im going to do about the trans cross member.
Check out my build on Facebook Ttoad Hurley its updated regularly
[Re: turbo toad]
#2004696
02/03/16 10:50 AM
02/03/16 10:50 AM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
They use the thru bolts for the front pump assembly on the glide to mate the bell to the trans. So i would say yes they do all have the same bolt pattern. Im in the process of test fitting my valiant for a glide now, and I have to figure out what im going to do about the trans cross member. Incorrect.........JW is the ONLY one that uses the front pump bell bolts. Reid and ATI both use a flange on the case that the bell bolts to and they are NOT the same pattern between the two
[Re: LA360]
#2004700
02/03/16 11:00 AM
02/03/16 11:00 AM
Posts: 2,813 Blue Ridge, VA
Plumb Wired
Blue Ridge, VA
JW bell mounts with the pump bolts. Reid, BTE & ATI the bell mounts to the transmission case, I don't know if the bells from one company will bolt to the case of another.
RIP Monte Smith
aka: OutlawFish '98 Bickel Dodge Dakota PST
[Re: LA360]
#2004717
02/03/16 11:37 AM
02/03/16 11:37 AM
Posts: 714 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
Reid and BTE are the same. ATI is it's own and JW bolts to the pump.
Without Data, you’re just another guy with an opinion.
[Re: Ian]
#2004773
02/03/16 01:22 PM
02/03/16 01:22 PM
Posts: 368 michigan
turbo toad
michigan
They use the thru bolts for the front pump assembly on the glide to mate the bell to the trans. So i would say yes they do all have the same bolt pattern. Im in the process of test fitting my valiant for a glide now, and I have to figure out what im going to do about the trans cross member. Incorrect.........JW is the ONLY one that uses the front pump bell bolts. Reid and ATI both use a flange on the case that the bell bolts to and they are NOT the same pattern between the two Thanks Monte i stand corrected im using a JW ultrabell and thought they all bolted up the same way [quote=Ian, trany mount all i done is weld a 2 inch plate to the mount and bolts up fine with the std xross member[/quote] Ian do you happen to have any pics of your trans cross member
[Re: sr4440]
#2004797
02/03/16 02:09 PM
02/03/16 02:09 PM
Monte_Smith
North Alabama
Reid and BTE are the same. ATI is it's own and JW bolts to the pump. This is correct......but I think BTE likely buys their bells from Reid. The JW would be my last choice for a Glide, if I was starting from scratch. Not a huge fan of the bell mounting to the pump bolts
[Re: Monte_Smith]
#2004859
02/03/16 03:28 PM
02/03/16 03:28 PM
Posts: 11,524 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Reid and BTE are the same. ATI is it's own and JW bolts to the pump. This is correct......but I think BTE likely buys their bells from Reid. The JW would be my last choice for a Glide, if I was starting from scratch. Not a huge fan of the bell mounting to the pump bolts Agreed. I've used the JW deal on a stock case. Have to pay attention to sealing the bolts to avoid leaks. Only reason/advantage to use JW's set up is the ability to use a stock case.
[Re: CMcAllister]
#2004879
02/03/16 03:48 PM
02/03/16 03:48 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
BTE has their own Chevy bells. They sell Reid for others. ATI is its own pattern. ATI turbo 400 customers can request the register machined down as they include the Reid pattern.
Quicktime also offers a few steel bells that use Reid pattern that are a higher still cert.
[Re: turbo toad]
#2004900
02/03/16 04:21 PM
02/03/16 04:21 PM
Posts: 1,044 Victoria, Australia
Ian
Victoria, Australia
[quote=turbo toad]They use the thru bolts for the front pump assembly on the glide to mate the bell to the trans. So i would say yes they do all have the same bolt pattern. Im in the process of test fitting my valiant for a glide now, and I have to figure out what im going to do about the trans cross member. Incorrect.........JW is the ONLY one that uses the front pump bell bolts. Reid and ATI both use a flange on the case that the bell bolts to and they are NOT the same pattern between the two Thanks Monte i stand corrected im using a JW ultrabell and thought they all bolted up the same way
Ian do you happen to have any pics of your trans cross member i will get a pic later today for you
