Powder coating torsion bars??? #2000275
01/28/16 03:24 AM
01/28/16 03:24 AM
Lansing, MI
70gtx440dana Offline OP
Lansing, MI
A friend suggested that powder coating torsion bars is not a good idea due to the heat they are subjected to in this process. Looking for opinions on if this would be a problem or not? Thanks in advance for any advice. Joe
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: Powder coating torsion bars??? [Re: 70gtx440dana] #2000332
01/28/16 11:05 AM
01/28/16 11:05 AM
robertop Offline
robertop  Offline
Powder coat is done at about 400 degrees, I believe; in that case the temperature is too low to affect the temper of the torsion bars.
Re: Powder coating torsion bars??? [Re: robertop] #2000337
01/28/16 11:12 AM
01/28/16 11:12 AM
None
71rm23 Offline
71rm23  Offline
None
X2 what robertop said. But if you do, tape off the hex end so they go in easy
Re: Powder coating torsion bars??? [Re: 70gtx440dana] #2000358
01/28/16 11:57 AM
01/28/16 11:57 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
POR-15 gives very good results on torsion bars. It looks very nearly original, is very tough and is neither expensive nor hard to put on.
Just a thought......
Master, again and still
Re: Powder coating torsion bars??? [Re: robertop] #2000415
01/28/16 01:46 PM
01/28/16 01:46 PM
Lansing, MI
Lansing, MI
That is what I was thinking too........seems like 400 deg or less should not be a problem in softening the temper.
Re: Powder coating torsion bars??? [Re: 70gtx440dana] #2000478
01/28/16 03:23 PM
01/28/16 03:23 PM
Greenfield, Tennessee, USA
CudaChick1968 Offline
As long as your chosen coater is qualified and experienced, you shouldn't have any problems.
Leanna ~ The CudaChick
Owner/Operator
http://PhoenixSpecialtyCoatings.com
731.613.9192 (10 a.m. - 9 p.m. Central)
Exceptional Custom Powder Coating & Metal Restoration
Re: Powder coating torsion bars??? [Re: CudaChick1968] #2000493
01/28/16 03:37 PM
01/28/16 03:37 PM
None
71rm23 Offline
71rm23  Offline
None
Send them to her!!!!!!!!!!!!!!!!!!!!
