Powder coating torsion bars???
#2000275
01/28/16 03:24 AM
01/28/16 03:24 AM
Posts: 3,527 Lansing, MI
70gtx440dana
Lansing, MI
A friend suggested that powder coating torsion bars is not a good idea due to the heat they are subjected to in this process. Looking for opinions on if this would be a problem or not? Thanks in advance for any advice. Joe
70 Road Runner 383-4 4 speed FJ5 & black guts 70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: Powder coating torsion bars???
[Re: robertop]
#2000337
01/28/16 11:12 AM
01/28/16 11:12 AM
Posts: 2,592 None
71rm23
None
Powder coat is done at about 400 degrees, I believe; in that case the temperature is too low to affect the temper of the torsion bars. X2 what robertop said. But if you do, tape off the hex end so they go in easy
[Re: 70gtx440dana]
#2000358
01/28/16 11:57 AM
01/28/16 11:57 AM
Posts: 12,233 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
POR-15 gives very good results on torsion bars. It looks very nearly original, is very tough and is neither expensive nor hard to put on.
Just a thought......
Master, again and still
[Re: robertop]
#2000415
01/28/16 01:46 PM
01/28/16 01:46 PM
70gtx440dana
Lansing, MI
Powder coat is done at about 400 degrees, I believe; in that case the temperature is too low to affect the temper of the torsion bars. That is what I was thinking too........seems like 400 deg or less should not be a problem in softening the temper.
[Re: CudaChick1968]
#2000493
01/28/16 03:37 PM
01/28/16 03:37 PM
Posts: 2,592 None
71rm23
None
As long as your chosen coater is qualified and experienced, you shouldn't have any problems. Send them to her!!!!!!!!!!!!!!!!!!!!
