CAN I MAKE MY OLD SCHOOL CHALL SOUND LIKE A HELLCAT? #1995756
01/21/16 07:36 PM
01/21/16 07:36 PM
Uranus
strokerchall Offline OP
Uranus
Can a guy buy hellcat components and use them on an old school mopar?
once you've stroked it,you'll wish you stroked it sooner
Re: CAN I MAKE MY OLD SCHOOL CHALL SOUND LIKE A HELLCAT? [Re: strokerchall] #1995767
01/21/16 07:42 PM
01/21/16 07:42 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
You would spend a stupid amount of money and have an exhaust system that needed to be hacked up and rewelded. Then, it would sound different due to the acoustics of the system.
That just covers the exhaust plumbing. Your engine and cam timing events would have to be reworked to achieve something similar at idle. Since the HC alters it's cam timing it sounds a tiny bit different at higher RPM. You have to pick one or the other.
In short, do what you can with what you've got. It'll never sound like a current production car.
- Stu Harmon
Re: CAN I MAKE MY OLD SCHOOL CHALL SOUND LIKE A HELLCAT? [Re: feets] #1995878
01/21/16 10:03 PM
01/21/16 10:03 PM
dogdays Offline
dogdays  Offline
Yes. It'll take a high quality digital recording , a bunch of speakers and a gaggle of amplifiers, plus the quietest mufflers for the actual engine.
I believe there was a movie about this a comedy with Kevin somebody and probably Will Ferrell. The movie was the new Challenger's introduction to many.
R.
Re: CAN I MAKE MY OLD SCHOOL CHALL SOUND LIKE A HELLCAT? [Re: strokerchall] #1995952
01/21/16 11:06 PM
01/21/16 11:06 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Hellcat crate engine $23K
Re: CAN I MAKE MY OLD SCHOOL CHALL SOUND LIKE A HELLCAT? [Re: strokerchall] #1996007
01/22/16 12:08 AM
01/22/16 12:08 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Why would you want to? The Hellcat sounds all mechanical to me. shruggy
Re: CAN I MAKE MY OLD SCHOOL CHALL SOUND LIKE A HELLCAT? [Re: strokerchall] #1996036
01/22/16 12:50 AM
01/22/16 12:50 AM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
If you want to mimic exhaust, why not go for the top of the mountain???
(Extra points for this Dart wading through a sea of G-as, T-ires, and O-il...)
https://youtu.be/JD0GU16eHmk
Re: CAN I MAKE MY OLD SCHOOL CHALL SOUND LIKE A HELLCAT? [Re: strokerchall] #1996100
01/22/16 03:06 AM
01/22/16 03:06 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
To each his own, but I'll take an old V8 with headers sound any day. Modern V8s sound like old trucks with exhaust manifolds to me.
Re: CAN I MAKE MY OLD SCHOOL CHALL SOUND LIKE A HELLCAT? [Re: Exit1965] #1996388
01/22/16 04:41 PM
01/22/16 04:41 PM
dogdays Offline
dogdays  Offline
I'm the opposite. I think the Ram1500 Hemi has one of the nicest stock sounds out there.
R.
Re: CAN I MAKE MY OLD SCHOOL CHALL SOUND LIKE A HELLCAT? [Re: strokerchall] #1999732
01/27/16 01:48 PM
01/27/16 01:48 PM
E
earlymopar Offline
earlymopar  Offline
E
You can (somewhat) reach your goal by using 180 degree headers on your engine. This type of header design optimizes the effect of exhaust scavaging and engine firing order. The down side to this style is that (often) the headers are a mess to route due to cross-over tubes that are required. If you have something with very little space in the engine bay or very little ground clearance, I wouldn't attempt it. The upside to this design is added horsepower and an exhaust note that sounds more like a high-winding over head cam or twin cam engine. They have been used in drag racing and in Nascar. The certainly do work well and sound great.
- EM
Re: CAN I MAKE MY OLD SCHOOL CHALL SOUND LIKE A HELLCAT? [Re: strokerchall] #1999800
01/27/16 03:27 PM
01/27/16 03:27 PM
League City, TX
BlueGhost Offline
BlueGhost  Offline
League City, TX
You could get close with a gear drive to get the whine, an X pipe, and small body straight trough mufflers. It may not run like a Hellcat, but it will make lots of noise.
1958 Plymouth Suburban
