CAN I MAKE MY OLD SCHOOL CHALL SOUND LIKE A HELLCAT?
#1995756
01/21/16 07:36 PM
01/21/16 07:36 PM
Posts: 441 Uranus
strokerchall
Uranus
Can a guy buy hellcat components and use them on an old school mopar?
once you've stroked it,you'll wish you stroked it sooner
Re: CAN I MAKE MY OLD SCHOOL CHALL SOUND LIKE A HELLCAT?
[Re: strokerchall]
#1995767
01/21/16 07:42 PM
01/21/16 07:42 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
You would spend a stupid amount of money and have an exhaust system that needed to be hacked up and rewelded. Then, it would sound different due to the acoustics of the system.
That just covers the exhaust plumbing. Your engine and cam timing events would have to be reworked to achieve something similar at idle. Since the HC alters it's cam timing it sounds a tiny bit different at higher RPM. You have to pick one or the other.
In short, do what you can with what you've got. It'll never sound like a current production car.
[Re: strokerchall]
#1996036
01/22/16 12:50 AM
01/22/16 12:50 AM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
If you want to mimic exhaust, why not go for the top of the mountain??? (Extra points for this Dart wading through a sea of G-as, T-ires, and O-il...) https://youtu.be/JD0GU16eHmk
[Re: strokerchall]
#1999800
01/27/16 03:27 PM
01/27/16 03:27 PM
Posts: 43 League City, TX
BlueGhost
League City, TX
You could get close with a gear drive to get the whine, an X pipe, and small body straight trough mufflers. It may not run like a Hellcat, but it will make lots of noise.
1958 Plymouth Suburban
