Machinist needed #1972857
12/19/15 08:06 PM
12/19/15 08:06 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
Anybody out here that can whittle this up out of aluminum doesn't have to have the legs it could be solid skirt.
Re: Machinist needed [Re: Scamp408] #1972914
12/19/15 09:25 PM
12/19/15 09:25 PM
Jerry Kathe Offline
Jerry Kathe  Offline
PM me a drawing with dimensions and your tolerances. Whats this for?
Re: Machinist needed [Re: Scamp408] #1972915
12/19/15 09:27 PM
12/19/15 09:27 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
That shouldn't be hard to make
Re: Machinist needed [Re: Scamp408] #1972960
12/19/15 10:33 PM
12/19/15 10:33 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Heck, even I should be able to turn that out an my little lathe.
If you want to PM me a blue print with tolerences I can see what I can do.
Re: Machinist needed [Re: Scamp408] #1973161
12/20/15 11:00 AM
12/20/15 11:00 AM
NC
440Jim Offline
440Jim  Offline
NC
A simple spring seat spacer is cheap. But, dimensions, tolerances, and detail features you want will drive cost..
Re: Machinist needed [Re: Scamp408] #1973169
12/20/15 11:36 AM
12/20/15 11:36 AM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
The spring I have to use.The legs hold it in place but I was thinking of a full skirt to go the length. It's a oil bypass for the 3.6 they don't sell it and even if they did it would be plastic junk. I will get spec and draw a picture..
Re: Machinist needed [Re: Scamp408] #1973175
12/20/15 11:48 AM
12/20/15 11:48 AM
NC
440Jim Offline
440Jim  Offline
NC
Does the large skirt need any holes? Either a bored\drilled center, or side holes\slots? What are the rough sizes? Skirt dia, spring pin dia,length? Specify if two outer diameters or more are needed.
Re: Machinist needed [Re: Scamp408] #1973216
12/20/15 01:19 PM
12/20/15 01:19 PM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
Might be a good candidate for a 3D printer, what's it made of?
Re: Machinist needed [Re: Scamp408] #1973228
12/20/15 01:54 PM
12/20/15 01:54 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
It's plastic but aluminum would last. It's does need the cage it could be solid.
Re: Machinist needed [Re: Scamp408] #1973230
12/20/15 01:57 PM
12/20/15 01:57 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
Inside of original spring chamber is .450
Re: Machinist needed [Re: Scamp408] #1973756
12/21/15 12:27 PM
12/21/15 12:27 PM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
Looks to be plastic impregnated with moly. The legs look like they slide inside a round bore. If you make an aluminum part to put in there it might seize up.
Re: Machinist needed [Re: Scamp408] #1973963
12/21/15 06:13 PM
12/21/15 06:13 PM
NC
440Jim Offline
440Jim  Offline
NC
This is his basic design, with no special angles or features. Just the diameters shown.
Re: Machinist needed [Re: Scamp408] #1973980
12/21/15 06:49 PM
12/21/15 06:49 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
Looks to me like a trip to the scrap yard would be easier.I'm quite sure the legs are there for a reason.
Re: Machinist needed [Re: Scamp408] #1974018
12/21/15 07:45 PM
12/21/15 07:45 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
You can cut away the side and make legs with a mill.
This parts about an hours time.
The O.D. is going to need to be on it.
I bet the legs are to help with flow.
Re: Machinist needed [Re: Scamp408] #1974056
12/21/15 09:15 PM
12/21/15 09:15 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
It's slides inside a plastic cage I don't think it's a flow problem there is plenty of room around it.as for used I have seen a lot of broken ones because of cheap plastic.
Re: Machinist needed [Re: Scamp408] #1974067
12/21/15 09:31 PM
12/21/15 09:31 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
Re: Machinist needed [Re: Scamp408] #1974385
12/22/15 10:10 AM
12/22/15 10:10 AM
moparx Offline
moparx  Offline
after looking at the video, i believe, if you look closer, the legs have a small tapered tab that allowes the assembly to slide together, then the end tabs "snaps outward" into the cage part preventing the spring from pushing the assembly apart. therefore, the legs need to be there as well as having a "foot"[?] to keep everything in one piece. with that being said, if a piece were to be made, i would hazard a guess you could come up with a way to hold everything together. i would have to have it in my hand to say for sure. personally, i have, over the years, disassembled and repaired many things that were never intended to be repaired and have the item[s] work as intended or designed for long periods of time after. i guess it just depends on your skill level, time YOU want to invest, and if it is acceptable for you to do things over [possibly multiple times before an acceptable out come is obtained] or if it just makes more sense to bite the bullet [and crab some] and replace the item in question. how much is this filter/cooler assembly anyway ? if it was already stated, please accept my apology for missing it.
beer
Re: Machinist needed [Re: Scamp408] #1974413
12/22/15 11:13 AM
12/22/15 11:13 AM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
The tabs hold it from coming if but since I will be doing the oil its not necessary. Most guys are making them or just not using it as I am now. The part is 200 and it takes 6 hours book time to install. This is another one of dodges great ideas and great engines which my opinion is crap. This will be my last dodge as I think aft fiat came in they went down hill. The car has 40'000 on it an this happened and the rad went bad which it comes out from the nose. They have also undersized the brakes which no matter what did it ate pads and rotors once a year. They would not warantee the oil cooler or the rad as I was told its a wear and tear item BS. They also would not comment on the brakes even though the new ones come with bigger rotors and calipers which I upgraded myself
Re: Machinist needed [Re: Scamp408] #1976335
12/25/15 09:53 PM
12/25/15 09:53 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
Installed
Re: Machinist needed [Re: Scamp408] #1976392
12/26/15 12:42 AM
12/26/15 12:42 AM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
Tapered
