Re: Machinist needed
[Re: Scamp408]
#1974385
12/22/15 10:10 AM
12/22/15 10:10 AM
Posts: 19,408 north of coder
moparx
after looking at the video, i believe, if you look closer, the legs have a small tapered tab that allowes the assembly to slide together, then the end tabs "snaps outward" into the cage part preventing the spring from pushing the assembly apart. therefore, the legs need to be there as well as having a "foot"[?] to keep everything in one piece. with that being said, if a piece were to be made, i would hazard a guess you could come up with a way to hold everything together. i would have to have it in my hand to say for sure. personally, i have, over the years, disassembled and repaired many things that were never intended to be repaired and have the item[s] work as intended or designed for long periods of time after. i guess it just depends on your skill level, time YOU want to invest, and if it is acceptable for you to do things over [possibly multiple times before an acceptable out come is obtained] or if it just makes more sense to bite the bullet [and crab some] and replace the item in question. how much is this filter/cooler assembly anyway ? if it was already stated, please accept my apology for missing it.
[Re: Scamp408]
#1974413
12/22/15 11:13 AM
12/22/15 11:13 AM
Posts: 2,709 NJ central
Scamp408
NJ central
The tabs hold it from coming if but since I will be doing the oil its not necessary. Most guys are making them or just not using it as I am now. The part is 200 and it takes 6 hours book time to install. This is another one of dodges great ideas and great engines which my opinion is crap. This will be my last dodge as I think aft fiat came in they went down hill. The car has 40'000 on it an this happened and the rad went bad which it comes out from the nose. They have also undersized the brakes which no matter what did it ate pads and rotors once a year. They would not warantee the oil cooler or the rad as I was told its a wear and tear item BS. They also would not comment on the brakes even though the new ones come with bigger rotors and calipers which I upgraded myself
