Controlling frost forming on race car in enclosed trailer. #1973444
12/20/15 08:31 PM
12/20/15 08:31 PM
Anoka County, MN
Leigh Offline OP
Leigh  Offline OP
Anoka County, MN
I was over at the trailer today, and was shocked to see the frost on EVERYTHING! The trailer is insulated. I understand the moisture/temp drop issue. If I tighten up the air leaks, (generator door), won't that just trap more moisture? I have a solar panel. I was thinking of a 12 volt bulb or piezo fan. Any ideas?
Re: Controlling frost forming on race car in enclosed trailer. [Re: Leigh] #1973455
12/20/15 08:47 PM
12/20/15 08:47 PM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
My guess is you closed it up when it was warmer and more humid out so the trapped moisture has frosted up on the cold surfaces.
You should had left the trailer cracked open till the temperature/humidity dropped, then sealed it up there would have been "less" frost but likely still some.
Insulation is just that, its not a heater! In MN I doubt anything short of an actual heater will do any good with the winters you get. A 12v bulb ain't gonna do squat !!
Re: Controlling frost forming on race car in enclosed trailer. [Re: Stanton] #1973461
12/20/15 08:52 PM
12/20/15 08:52 PM
Anoka County, MN
Leigh Offline OP
Leigh  Offline OP
Anoka County, MN
Yes, you're right on all three accounts. At least I fogged the heck out of it. Next year, I'll add a max air vent cover, and leave the inside cover cracked. That would allow some cross flow from the generator door vent.
Re: Controlling frost forming on race car in enclosed trailer. [Re: Leigh] #1973474
12/20/15 09:32 PM
12/20/15 09:32 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Since you say you have a solar panel I'm guessing its hooked up to a 12 volt battery. I would try a 12 volt oscillating fan to keep the air moving some. worth the try and I'm glad you fogged the engine.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Controlling frost forming on race car in enclosed trailer. [Re: Leigh] #1973477
12/20/15 09:40 PM
12/20/15 09:40 PM
Can , Nova Scotia , Cape Breto...
caper Offline
caper  Offline
A bail of hay spread out on the floor
New best 10.18 , 1.40 60 ft 496 Scott Brown built, street driven 3600 lbs,654 hp , 653 ft tq
Re: Controlling frost forming on race car in enclosed trailer. [Re: Leigh] #1973478
12/20/15 09:42 PM
12/20/15 09:42 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
I don't know if people typically use them on trailers but sailboat people seem to use solar powered fans like these:
http://www.defender.com/category.jsp?path=-1|6880|2290139&id=2290144
Re: Controlling frost forming on race car in enclosed trailer. [Re: Blusmbl] #1973505
12/20/15 10:46 PM
12/20/15 10:46 PM
Ontario, Canada
Don't question me!
Don't question me!
Ontario, Canada
He wants to keep his car dry, not build a manger !!
Re: Controlling frost forming on race car in enclosed trailer. [Re: Stanton] #1973506
12/20/15 10:50 PM
12/20/15 10:50 PM
IN
ahy Offline
ahy  Offline
IN
If you have a dry day or two or three I'd crack the door now. Colder the better. That will help get the moisture out even when frozen.
Re: Controlling frost forming on race car in enclosed trailer. [Re: Leigh] #1973509
12/20/15 11:03 PM
12/20/15 11:03 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Just put in a 1500w heater...
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Controlling frost forming on race car in enclosed trailer. [Re: Leigh] #1973516
12/20/15 11:13 PM
12/20/15 11:13 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Seal it up and put a dessacant in there, a 5 gallon bucket of salt in the corner (not dumped every where) a very dry hay bail can absorb moisture.
You could heat it till it thaws and dries with an electric heater then open the doors and blow out the moist warm air and let it fill with cold dry air and seal it back up. Don't use a propane heater as a by-product of combustion is water.
Re: Controlling frost forming on race car in enclosed trailer. [Re: Leigh] #1973529
12/20/15 11:48 PM
12/20/15 11:48 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Really? I actually have trouble finding mine in all the "frost"....
Oooh, there it is....
Re: Controlling frost forming on race car in enclosed trailer. [Re: Dragula] #1973544
12/21/15 12:23 AM
12/21/15 12:23 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
I was gunna aSK WHAT FROST WAS BUT THE I SAW YOUR PIC,S. smoke
Re: Controlling frost forming on race car in enclosed trailer. [Re: Leigh] #1973551
12/21/15 12:29 AM
12/21/15 12:29 AM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
When I lived in Michigan I never had that problem. I always left my roof vents opened a couple inches. Let's the air circulate.
Re: Controlling frost forming on race car in enclosed trailer. [Re: Leigh] #1973554
12/21/15 12:42 AM
12/21/15 12:42 AM
Ontario, Canada
Don't question me!
Don't question me!
Ontario, Canada
The added bonus of running a heater is in the spring when you open the trailer to the warm, moist outside air, the car won't be so cold as to have condensation form on it ... y'know, like a cold beer on a warm day !!!
Re: Controlling frost forming on race car in enclosed trailer. [Re: Leigh] #1973558
12/21/15 12:44 AM
12/21/15 12:44 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
What about a dehumidifier? Or one of those portable electric heater/units? Obviously not on the floor where fuel/oil fumes could ignite. Maybe plug it in every few days. Humidity will attack everything - tools, etc - in the trailer.
Re: Controlling frost forming on race car in enclosed trailer. [Re: topside] #1973586
12/21/15 01:31 AM
12/21/15 01:31 AM
Anoka County, MN
Leigh Offline OP
Leigh  Offline OP
Anoka County, MN
No power available where it's at. I'm going with opening up the roof vent. That trainer snow picture looks like May in Minnesota. 😄
Re: Controlling frost forming on race car in enclosed trailer. [Re: Leigh] #1973598
12/21/15 01:49 AM
12/21/15 01:49 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
put it inside! DUH!!! smile
Re: Controlling frost forming on race car in enclosed trailer. [Re: J_BODY] #1973604
12/21/15 02:00 AM
12/21/15 02:00 AM
Anoka County, MN
Leigh Offline OP
Leigh  Offline OP
Anoka County, MN
20'X20'. No extra room. It's good that I don't smoke, there isn't room for a pack. 😳
Re: Controlling frost forming on race car in enclosed trailer. [Re: Leigh] #1974243
12/22/15 12:54 AM
12/22/15 12:54 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Open the vent, mom used to dry clothes when it was below zero, freeze dried. Always heard it's a " dry cold" up there. Cold should suck the moisture out. What is the humidity outside right now?
Re: Controlling frost forming on race car in enclosed trailer. [Re: Dabee] #1974935
12/23/15 01:54 AM
12/23/15 01:54 AM
Byron, NY
W.I.N. Racing Offline
Byron, NY
iagree
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
