Re: Controlling frost forming on race car in enclosed trailer.
[Re: Leigh]
#1973474
12/20/15 09:32 PM
12/20/15 09:32 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Since you say you have a solar panel I'm guessing its hooked up to a 12 volt battery. I would try a 12 volt oscillating fan to keep the air moving some. worth the try and I'm glad you fogged the engine.
[Re: Leigh]
#1973478
12/20/15 09:42 PM
12/20/15 09:42 PM
Posts: 8,182 Plymouth, MI
Blusmbl
Plymouth, MI
I don't know if people typically use them on trailers but sailboat people seem to use solar powered fans like these:
http://www.defender.com/category.jsp?path=-1|6880|2290139&id=2290144
[Re: Blusmbl]
#1973505
12/20/15 10:46 PM
12/20/15 10:46 PM
Posts: 8,908 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
A bail of hay spread out on the floor He wants to keep his car dry, not build a manger !!
[Re: Leigh]
#1973509
12/20/15 11:03 PM
12/20/15 11:03 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Just put in a 1500w heater...
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: Leigh]
#1973516
12/20/15 11:13 PM
12/20/15 11:13 PM
Posts: 12,423 Kalispell Mt.
HotRodDave
Kalispell Mt.
Seal it up and put a dessacant in there, a 5 gallon bucket of salt in the corner (not dumped every where) a very dry hay bail can absorb moisture.
You could heat it till it thaws and dries with an electric heater then open the doors and blow out the moist warm air and let it fill with cold dry air and seal it back up. Don't use a propane heater as a by-product of combustion is water.
[Re: Dabee]
#1974935
12/23/15 01:54 AM
12/23/15 01:54 AM
Posts: 2,118 Byron, NY
W.I.N. Racing
Byron, NY
I always left my roof vents opened a couple inches. Let's the air circulate.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
