Re: SuperBrightLEDs and chrysler 1 wire sockets :(
[Re: shawge]
#1972180
12/18/15 04:01 PM
12/18/15 04:01 PM
Posts: 315 Ontario, Canada
RealWing
Ontario, Canada
SWitch the polarity to the LED.
1970 Superbird 440-6bbl, auto 1969 Barracuda 340-4bbl, FB Formula S auto 1969 Barracuda 6.1 L Hemi, 5 speed, Convertible 2022 Can Am Spyder RTL
[Re: OLD318]
#1972249
12/18/15 06:28 PM
12/18/15 06:28 PM
Posts: 220 Portland, OR
shawge
Portland, OR
Check voltage at socket, and check if bulb is making contact with socket supply and ground.
Edit - check the bulb. A 9 volt battery may work or directly to the car battery. I use a battery charger on low, some leads with small alligator clips, and steady hands.
