SuperBrightLEDs and chrysler 1 wire sockets :( #1972020
12/18/15 11:11 AM
12/18/15 11:11 AM
O
OLD318 Offline OP
OLD318  Offline OP
O
Hey team, I keep having this issue when I try to replace an interior one-wire light bulb with the LED equivalent.
Take the glovebox light 1 wire, grounds to dash panel.
if pull the glove box light out and physically ground it to say
the glove box latch...the stock bulb lights up..as it should!
When I replace the bulb with the LED equivalent...which fits
the socket perfectly...I can never get it to work...
Same with the ashtray light.... etc..
Does anybody know why? its supposed to be a direct replacement
I have several and none of them work.... Bulbs are all brand new...
Anybody do this conversion?
Re: SuperBrightLEDs and chrysler 1 wire sockets :( [Re: OLD318] #1972132
12/18/15 02:43 PM
12/18/15 02:43 PM
Portland, OR
shawge Offline
shawge  Offline
Portland, OR
What is the voltage at the socket? Incandescent bulbs work at sub-par voltages, LEDs not so much.
Re: SuperBrightLEDs and chrysler 1 wire sockets :( [Re: shawge] #1972180
12/18/15 04:01 PM
12/18/15 04:01 PM
Ontario, Canada
RealWing Offline
RealWing  Offline
Ontario, Canada
SWitch the polarity to the LED.
1970 Superbird 440-6bbl, auto
1969 Barracuda 340-4bbl, FB Formula S auto
1969 Barracuda 6.1 L Hemi, 5 speed, Convertible
2022 Can Am Spyder RTL
Re: SuperBrightLEDs and chrysler 1 wire sockets :( [Re: OLD318] #1972199
12/18/15 04:55 PM
12/18/15 04:55 PM
O
OLD318 Offline OP
OLD318  Offline OP
O
How do you switch the polarity?
Re: SuperBrightLEDs and chrysler 1 wire sockets :( [Re: OLD318] #1972201
12/18/15 04:57 PM
12/18/15 04:57 PM
Calgary, Alberta Canada
a12rag Online content
a12rag  Online Content
Swap the wires
Re: SuperBrightLEDs and chrysler 1 wire sockets :( [Re: a12rag] #1972221
12/18/15 05:40 PM
12/18/15 05:40 PM
O
OLD318 Offline OP
OLD318  Offline OP
O
These are both 1 wire sockets...not 2 wire
Re: SuperBrightLEDs and chrysler 1 wire sockets :( [Re: OLD318] #1972249
12/18/15 06:28 PM
12/18/15 06:28 PM
Portland, OR
shawge Offline
shawge  Offline
Portland, OR
Check voltage at socket, and check if bulb is making contact with socket supply and ground.
Edit - check the bulb. A 9 volt battery may work or directly to the car battery. I use a battery charger on low, some leads with small alligator clips, and steady hands.
Re: SuperBrightLEDs and chrysler 1 wire sockets :( [Re: OLD318] #1972676
12/19/15 02:30 PM
12/19/15 02:30 PM
delivering your oil
nutso suave Offline
nutso suave  Offline
delivering your oil
Some LEDs are polarity sensitive, as mentioned above, and some LEDs don't work properly unless they have the correct voltage, unlike an incandescent which just gets dimmer.
