Challenger T/A hood pins #1968505
12/12/15 06:16 PM
12/12/15 06:16 PM
Crook County, ILL
Mastershake340 Offline OP
Crook County, ILL
I'm trying to get parts together to complete putting together my T/A project. When the restoration shop disassembled my hood pins years back they put the parts in a bag, and I believe they are original to the car as I have owned it since '78.
A few things I am not 100% certain on I'm hoping I can get clarification on.
First, the plates on my hood were held on by phillips head screws. I checked the survivor sibling of my car, 2 VIN after mine and its plates were attached to the hood with screws. The repro kits I see for T/As have rivets and the ones for other than Trans Am cars have screws. I checked Barry's DVD of the "173 mile T/A" and its plates are riveted.
So what gives, it looks like they were supposed to be riveted on, but did some get riveted and others attached with screws? Or could the hood on both my car and my twin's have been damaged years ago and both hood pin plates screwed on when the new hoods installed?
Looking at pictures like Barry's DVD of the hood pin installed to the fender skirt, there appears to be a washer or spacer installed between the nut and the fender. No such washers in my bag of parts removed from the car. I'm guessing there were washers but mine were lost or swiped in the last 16 years the car has been away between 2 shops etc.
I don't see them in pictures of the parts you get with the repro kits. Are they a standard size that I can get at the hardware store, or if not, available someplace? Plated or painted?
I had my original pins and plates polished and restored by my friend Tom, who is a trim resto guru who works with Special T's. They look great! I'm planning to use them along with some repro parts for the hood pin installation on my car.
Re: Challenger T/A hood pins [Re: Mastershake340] #1969422
12/14/15 01:47 PM
12/14/15 01:47 PM
Canada
Maxwellwedge Offline
Canada
Frank Badalson has those thick concave washers. they go under the nut on the top side. They install a certain way.....I believe with the "cupped" edges facing up. The star washer goes on the underside.
Never seen anything but rivets on a T/A, AAR or A12.
Re: Challenger T/A hood pins [Re: Maxwellwedge] #1969471
12/14/15 03:06 PM
12/14/15 03:06 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Agreed, only seen rivets on T/A-AAR's, A12 has 3 rivets one screw per bezel to retain lanyard IIRC
Re: Challenger T/A hood pins [Re: Mastershake340] #1969475
12/14/15 03:23 PM
12/14/15 03:23 PM
canada
sailboat Offline
sailboat  Offline
canada
All hood plates were riveted. I bought my T/A new in May of 1971. Based upon what i can make out from your photo,your pins are not the orginal pins either. The original pins were more "flat" on the extreme round part of the curve on your pin. The "curve" wasnt as long either. Your lanyards are correct, cant tell about your plates from the pic.
Re: Challenger T/A hood pins [Re: Mastershake340] #1969632
12/14/15 06:56 PM
12/14/15 06:56 PM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
I thought steel hoods had screws and 'glass hoods had rivits?
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: Challenger T/A hood pins [Re: RoadRunner] #1969667
12/14/15 08:00 PM
12/14/15 08:00 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Correct, but the topic of this thread is for T/A hoods...
Brad, as someone has mentioned{and your hood plate screws confirm} some of the hoodpin hardware does'nt look original...Here's a comparison shot of the other components from a previous thread...
Re: Challenger T/A hood pins [Re: screamindriver] #1969923
12/15/15 02:08 AM
12/15/15 02:08 AM
Crook County, ILL
Crook County, ILL
Great info here, thanks! beer
I mispoke with my mention of pins, I guess studs is a better term for the components I had polished, along with the plates or bezels.
I hadn't given much thought to the pins, and now based on the info posted here I am wondering which of the ones I have here are original and correct.
Here are the ones I posted before along with a couple others I had in the bag of hood pin components. The ones on the lanyards are about 2-5/8" long.
The loose ones are about 3-3/8" long. Are they correct?
The parts I am missing are shown in the second picture of Tim Welborn's former survivor T/A and looks like the middle picture screamindriver posted. Are these a standard size, or available from a restoration parts supplier?
Re: Challenger T/A hood pins [Re: Mastershake340] #1970030
12/15/15 10:22 AM
12/15/15 10:22 AM
MA
steve70 Offline
steve70  Offline
MA
The shorter ones look closer to original but my 32K mile car has more of a D-shape at the top.The second picture is the original hardware.
1970 Challenger T/A 4 speed
Re: Challenger T/A hood pins [Re: Mastershake340] #1970139
12/15/15 01:47 PM
12/15/15 01:47 PM
Canada
Canada
I would just get the complete kit from Frank Badalson.
He has done all the research and his stuff is the most correct out there.
Re: Challenger T/A hood pins [Re: Mastershake340] #1970385
12/15/15 08:40 PM
12/15/15 08:40 PM
Lee Co. Fla.
5carguy Online content
5carguy  Online Content
Lee Co. Fla.
iagreeHis parts are not cheap,but they are correct.
Re: Challenger T/A hood pins [Re: 5carguy] #1970408
12/15/15 08:58 PM
12/15/15 08:58 PM
Crook County, ILL
Crook County, ILL
I am going to need to get a shopping list together of stuff to buy from Frank, so I might end up buying a hood pin kit from him at the same time.
I see he has those washer/spacers or whatever they are called, that I am missing. That has been one of my main concerns.
