Challenger T/A hood pins
#1968505
12/12/15 06:16 PM
12/12/15 06:16 PM
Posts: 8,341 Crook County, ILL
Mastershake340
Crook County, ILL
I'm trying to get parts together to complete putting together my T/A project. When the restoration shop disassembled my hood pins years back they put the parts in a bag, and I believe they are original to the car as I have owned it since '78. A few things I am not 100% certain on I'm hoping I can get clarification on. First, the plates on my hood were held on by phillips head screws. I checked the survivor sibling of my car, 2 VIN after mine and its plates were attached to the hood with screws. The repro kits I see for T/As have rivets and the ones for other than Trans Am cars have screws. I checked Barry's DVD of the "173 mile T/A" and its plates are riveted. So what gives, it looks like they were supposed to be riveted on, but did some get riveted and others attached with screws? Or could the hood on both my car and my twin's have been damaged years ago and both hood pin plates screwed on when the new hoods installed? Looking at pictures like Barry's DVD of the hood pin installed to the fender skirt, there appears to be a washer or spacer installed between the nut and the fender. No such washers in my bag of parts removed from the car. I'm guessing there were washers but mine were lost or swiped in the last 16 years the car has been away between 2 shops etc. I don't see them in pictures of the parts you get with the repro kits. Are they a standard size that I can get at the hardware store, or if not, available someplace? Plated or painted? I had my original pins and plates polished and restored by my friend Tom, who is a trim resto guru who works with Special T's. They look great! I'm planning to use them along with some repro parts for the hood pin installation on my car.
![Name: Hood pins.jpg
ID: 220622 Hood pins.jpg](/ubbthreads/ubbthreads.php/ubb/download/Number/220622/filename/Hood pins.jpg)
Re: Challenger T/A hood pins
[Re: Maxwellwedge]
#1969471
12/14/15 03:06 PM
12/14/15 03:06 PM
Posts: 18,160 Mass
DAYCLONA
Mass
Never seen anything but rivets on a T/A, AAR or A12. Agreed, only seen rivets on T/A-AAR's, A12 has 3 rivets one screw per bezel to retain lanyard IIRC
[Re: Mastershake340]
#1969632
12/14/15 06:56 PM
12/14/15 06:56 PM
Posts: 5,140 East Aurora (Buffalo) NY
RoadRunner
I thought steel hoods had screws and 'glass hoods had rivits?
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
[Re: RoadRunner]
#1969667
12/14/15 08:00 PM
12/14/15 08:00 PM
Posts: 7,196 Harrisburg, Pa.
screamindriver
Harrisburg, Pa.
I thought steel hoods had screws and 'glass hoods had rivits? Correct, but the topic of this thread is for T/A hoods... Brad, as someone has mentioned{and your hood plate screws confirm} some of the hoodpin hardware does'nt look original...Here's a comparison shot of the other components from a previous thread...
[Re: screamindriver]
#1969923
12/15/15 02:08 AM
12/15/15 02:08 AM
Mastershake340
Crook County, ILL
Great info here, thanks! I mispoke with my mention of pins, I guess studs is a better term for the components I had polished, along with the plates or bezels. I hadn't given much thought to the pins, and now based on the info posted here I am wondering which of the ones I have here are original and correct. Here are the ones I posted before along with a couple others I had in the bag of hood pin components. The ones on the lanyards are about 2-5/8" long. The loose ones are about 3-3/8" long. Are they correct? The parts I am missing are shown in the second picture of Tim Welborn's former survivor T/A and looks like the middle picture screamindriver posted. Are these a standard size, or available from a restoration parts supplier?
#1970030
12/15/15 10:22 AM
12/15/15 10:22 AM
Posts: 892 MA
steve70
MA
The shorter ones look closer to original but my 32K mile car has more of a D-shape at the top.The second picture is the original hardware.
1970 Challenger T/A 4 speed
