What is up with the Quantas fan belt? #1966578
12/09/15 09:47 PM
12/09/15 09:47 PM
FLPlum Offline OP
FLPlum  Offline OP
Hello
Need to replace my A/C belts. They are totally stretched and keep flipping.
440 Magnum 1970.
Any ideas on good original looking belts??
Is Quantas producing better quality these days?
Thank You
Re: What is up with the Quantas fan belt? [Re: FLPlum] #1966686
12/09/15 11:57 PM
12/09/15 11:57 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Isn't Quantas an Australian airline ?!?!?!?
Re: What is up with the Quantas fan belt? [Re: FLPlum] #1966703
12/10/15 12:14 AM
12/10/15 12:14 AM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Save your OE looking belts for the shows and run Gates for all other times..
Re: What is up with the Quantas fan belt? [Re: FLPlum] #1966726
12/10/15 12:32 AM
12/10/15 12:32 AM
BlueRacer69 Offline
BlueRacer69  Offline
I think Goodyear makes belts too. Don't know about the quality of them though.
Re: What is up with the Quantas fan belt? [Re: FLPlum] #1966732
12/10/15 12:43 AM
12/10/15 12:43 AM
Mechanicsburg, PA
LemonTwiist Offline
LemonTwiist  Offline
Mechanicsburg, PA
Don't waste your time with them. They are junk and have been flipping and stretching for years. They No body buys them any more if they intend to drive their cars
Re: What is up with the Quantas fan belt? [Re: FLPlum] #1966825
12/10/15 02:39 AM
12/10/15 02:39 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
To get a quality belt with pentastar, it was suggested here that maybe you could convince a dealer parts desk guy to find an OEM V-belt that is the correct size. The belts might need to be measured if no size chart exists.
If the dealer still has V-belts, maybe they are later applications like Jeep and can't be identified by the 1960s-70s muscle car part numbers.
How to measure belts link
Re: What is up with the Quantas fan belt? [Re: FLPlum] #1966957
12/10/15 11:39 AM
12/10/15 11:39 AM
FLPlum Offline OP
FLPlum  Offline OP
Thanks for the help.
It looks like the best option is to run quality belts, if driven.
I've tried to keep all looking original under hood.
Does anyone know if the white paint on belts ca be removed?
At lease it is all black. That would be preferred.
Thanks,
Mike
Re: What is up with the Quantas fan belt? [Re: FLPlum] #1967005
12/10/15 12:51 PM
12/10/15 12:51 PM
BlueRacer69 Offline
BlueRacer69  Offline
If you end up buying a aftermarket belt and it has white painted numbers or a company`s name printed on the belt that you don't want seen, you mite try going over it with a black marks-a-lot a few times to cover it up. Just a thought.
Re: What is up with the Quantas fan belt? [Re: FLPlum] #1967018
12/10/15 01:14 PM
12/10/15 01:14 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Yes, you can remove the ink from a new belt. I did it on mine. I don't remember exactly what I used but it wasn't difficult. I might have rubbed it with paint thinner or acetone.
Re: What is up with the Quantas fan belt? [Re: FLPlum] #1969307
12/14/15 02:26 AM
12/14/15 02:26 AM
htpd437
htpd437
Ah yes, the good ol' Quanta stretching stories. I had my share of those woes. My alternator belt came off which got between the pulley and made the power steering belt come off. Its a shame they didn't fix the issue. Just another crappy repro part out there that no one decided to fix and take our hard earned money. I run Gates now if I can find them. Originality is nice, but then again, having a car stay driving on the road is nicer !
Re: What is up with the Quantas fan belt? [Re: FLPlum] #1970577
12/16/15 12:41 AM
12/16/15 12:41 AM
BlueRacer69 Offline
BlueRacer69  Offline
Does anyone here know the Gates part number for a 1969 440 fan-alternator belt? I`m told it measures something like 3/8" by 46 inch. Is that correct? Thanks.
Re: What is up with the Quantas fan belt? [Re: BlueRacer69] #1970769
12/16/15 12:58 PM
12/16/15 12:58 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
If it's 46" it's a 7460 45" 7450 etc...
Ron
Re: What is up with the Quantas fan belt? [Re: FLPlum] #1970885
12/16/15 04:21 PM
12/16/15 04:21 PM
BlueRacer69 Offline
BlueRacer69  Offline
Got it. Thanks for that info Ron.
Re: What is up with the Quantas fan belt? [Re: FLPlum] #1976872
12/27/15 12:42 AM
12/27/15 12:42 AM
St.Louis,Mo.
70RR383 Offline
70RR383  Offline
St.Louis,Mo.
I still buy them from my local dodge dealer.ALL 4!!!!
Re: What is up with the Quantas fan belt? [Re: FLPlum] #1976889
12/27/15 01:19 AM
12/27/15 01:19 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
iagree
