SB 318 rope rear main seal available? #1965055
12/07/15 06:58 PM
12/07/15 06:58 PM
Central Valley, CA.
Quicksilver440 Offline OP
Central Valley, CA.
I can't find anyone who lists a SB 318 Rope rear main seal....I can only find them for BB's. Does anyone know if they are available? And where can I actually buy one?
This is my first venture with a SB....so I've got lots to learn.
Thanks,
Rob
Re: SB 318 rope rear main seal available? [Re: Quicksilver440] #1965075
12/07/15 07:44 PM
12/07/15 07:44 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Fel-Pro BS11748 is a rope seal. I would think it would work on that engine. Let others check in that know for sure.
Re: SB 318 rope rear main seal available? [Re: mopars4ever] #1965091
12/07/15 08:20 PM
12/07/15 08:20 PM
Car Quest. Reinz JV551
Re: SB 318 rope rear main seal available? [Re: Quicksilver440] #1965142
12/07/15 09:57 PM
12/07/15 09:57 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Both the above numbers are for BB's, not SB's.
Don't be the exception.
Re: SB 318 rope rear main seal available? [Re: Quicksilver440] #1965171
12/07/15 10:42 PM
12/07/15 10:42 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Why would you want one? I've never had the neoprene ones leak.
Doug
Re: SB 318 rope rear main seal available? [Re: Supercuda] #1965190
12/07/15 11:01 PM
12/07/15 11:01 PM
Correct but they will work (correctly) on SB's
Re: SB 318 rope rear main seal available? [Re: Supercuda] #1965196
12/07/15 11:08 PM
12/07/15 11:08 PM
Central Valley, CA.
Central Valley, CA.
Supercuda...I had looked at both of those too and had seen they were listed for BB's. Robert...So these will work on SB's no problem? You've done it I take it?
The reason I want a rope seal is that my crank has the knurl/crosshatching meant for a rope seal, and I have never had a rope seal leak but always read about people having problems using a rubber seal on a knurled/crosshatched crank. If it's in question....I would rather use a rope seal that through experience, I know works.
I'm open to other opinions though....
Re: SB 318 rope rear main seal available? [Re: Quicksilver440] #1965202
12/07/15 11:20 PM
12/07/15 11:20 PM
yes several times. I forgot the other word in the brand name when I posted; "Victor" Reinz JV551
Re: SB 318 rope rear main seal available? [Re: Quicksilver440] #1965259
12/08/15 12:09 AM
12/08/15 12:09 AM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
Got my last Victor JV551 rope seal from Autozone. They are cut-to-fit so they will work in both BB and SB.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: SB 318 rope rear main seal available? [Re: 71yelladustr] #1965265
12/08/15 12:17 AM
12/08/15 12:17 AM
Central Valley, CA.
Central Valley, CA.
Thanks Robert and Yella...that's what I needed to know. up
Re: SB 318 rope rear main seal available? [Re: Quicksilver440] #1965623
12/08/15 03:29 PM
12/08/15 03:29 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
You will end up trimming them to fit anyway. I prefer rope over a lip seal unless it's a car they plan to race. Rope doesn't leak. They don't seap. Ever.
Re: SB 318 rope rear main seal available? [Re: Quicksilver440] #1965678
12/08/15 04:50 PM
12/08/15 04:50 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
BEST Gasket has the best rope seal , the Fel pro is made of too hard a material and doesn't last, I'm pretty sure original rope seal had asbestos in them and that is gone from being used now.
http://www.bestgasket.com/
Re: SB 318 rope rear main seal available? [Re: JohnRR] #1965820
12/08/15 07:53 PM
12/08/15 07:53 PM
Erda, UT
67Charger Offline
67Charger  Offline
Erda, UT
Rob,
WHAT are you doing with a SB?!?!?
11.33 @ 118.46 on motor
10.75 @ 125.35 w/ a little spray
Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race
Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
Re: SB 318 rope rear main seal available? [Re: JohnRR] #1966054
12/09/15 01:20 AM
12/09/15 01:20 AM
Central Valley, CA.
Central Valley, CA.
Moper...I agree!
John...I have been looking for someone who sells the Best rope seal online...havnt found it yet, but I am looking.
Re: SB 318 rope rear main seal available? [Re: 67Charger] #1966059
12/09/15 01:31 AM
12/09/15 01:31 AM
Central Valley, CA.
Central Valley, CA.
Dan! If you remember my son Bobby (Robert) from "Pinks"...he just turned 17 and is building a '64 Sweptline short bed pickup for his daily driver. 318 with a 4-speed (833). He was building a 440 with a spare block I had in the garage, but when it went to the machine shop a few weeks ago we found out it was cracked. down
Good thing I dragged it to three different houses over the years.He decided just to expedite things and pulled a 318 out of a van at the junkyard on 40% day on thanksgiving morning. He wants to put some magnum heads on it and just drive it since I couldn't find another block that didn't cost me a fortune.
Re: SB 318 rope rear main seal available? [Re: Quicksilver440] #1966369
12/09/15 03:46 PM
12/09/15 03:46 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Recently spent 2 days removing top half of a leaky rope seal in Y block in our 55 T Bird. Installed a neoprene seal, no more leak 'yet' anyway. Was faced with pulling engine until devising a rather homegrown Bubba solution that got it out. Sneaky Pete tool to remove proved worthless.
I do not believe that is recommended to install a rope seal unless crankshaft is removed from engine. These Sneaky Pete solutions to pull a new top half in with crank installed at prove problematic at best. They can stretch the new seal and oft times you will find that seal is not properly seated in block and will leak.
Advice as suggested earlier, try a neoprene seal first.
Re: SB 318 rope rear main seal available? [Re: JohnRR] #1967586
12/11/15 06:11 AM
12/11/15 06:11 AM
Central Valley, CA.
Central Valley, CA.
I found the BEST part # is 5263 for all mopar v8's and they sell them online at Marxparts.com
Re: SB 318 rope rear main seal available? [Re: Sxrxrnr] #1967742
12/11/15 02:42 PM
12/11/15 02:42 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
I would suggest if someone is to try this, to first trim the rope where the tool will grab so it's a fresh cut and not frayed, pull the seal in from the driver's side up over the crank, and turn the crank in the same direction as and at the same time as you pull it in. This is reverse of the way the crank normally rotates. The "sneaky Pete" has been successfully used for decades.
