Re: SB 318 rope rear main seal available?
[Re: Quicksilver440]
#1965142
12/07/15 09:57 PM
12/07/15 09:57 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Both the above numbers are for BB's, not SB's.
[Re: Supercuda]
#1965190
12/07/15 11:01 PM
12/07/15 11:01 PM
RapidRobert
Both the above numbers are for BB's, not SB's. Correct but they will work (correctly) on SB's
#1965202
12/07/15 11:20 PM
12/07/15 11:20 PM
RapidRobert
yes several times. I forgot the other word in the brand name when I posted; "Victor" Reinz JV551
#1965259
12/08/15 12:09 AM
12/08/15 12:09 AM
Posts: 1,035 Missouri U.S.A.
71yelladustr
Missouri U.S.A.
Got my last Victor JV551 rope seal from Autozone. They are cut-to-fit so they will work in both BB and SB.
392 gen III hemi on E-85 727 trans Dana 60 10.02@134
#1965623
12/08/15 03:29 PM
12/08/15 03:29 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
You will end up trimming them to fit anyway. I prefer rope over a lip seal unless it's a car they plan to race. Rope doesn't leak. They don't seap. Ever.
#1965678
12/08/15 04:50 PM
12/08/15 04:50 PM
Posts: 74,978 U.S.S.A.
JohnRR
U.S.S.A.
BEST Gasket has the best rope seal , the Fel pro is made of too hard a material and doesn't last, I'm pretty sure original rope seal had asbestos in them and that is gone from being used now. http://www.bestgasket.com/
[Re: JohnRR]
#1965820
12/08/15 07:53 PM
12/08/15 07:53 PM
Posts: 3,031 Erda, UT
67Charger
Erda, UT
Rob,
WHAT are you doing with a SB?!?!?
11.33 @ 118.46 on motor 10.75 @ 125.35 w/ a little spray Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
[Re: JohnRR]
#1967586
12/11/15 06:11 AM
12/11/15 06:11 AM
Posts: 10,766 Central Valley, CA.
Quicksilver440
Central Valley, CA.
BEST Gasket has the best rope seal , the Fel pro is made of too hard a material and doesn't last, I'm pretty sure original rope seal had asbestos in them and that is gone from being used now. http://www.bestgasket.com/ I found the BEST part # is 5263 for all mopar v8's and they sell them online at Marxparts.com
[Re: Sxrxrnr]
#1967742
12/11/15 02:42 PM
12/11/15 02:42 PM
moper
Columbia, CT
Recently spent 2 days removing top half of a leaky rope seal in Y block in our 55 T Bird. Installed a neoprene seal, no more leak 'yet' anyway. Was faced with pulling engine until devising a rather homegrown Bubba solution that got it out. Sneaky Pete tool to remove proved worthless.
I do not believe that is recommended to install a rope seal unless crankshaft is removed from engine. These Sneaky Pete solutions to pull a new top half in with crank installed at prove problematic at best. They can stretch the new seal and oft times you will find that seal is not properly seated in block and will leak.
Advice as suggested earlier, try a neoprene seal first. I would suggest if someone is to try this, to first trim the rope where the tool will grab so it's a fresh cut and not frayed, pull the seal in from the driver's side up over the crank, and turn the crank in the same direction as and at the same time as you pull it in. This is reverse of the way the crank normally rotates. The "sneaky Pete" has been successfully used for decades.
