Page 8 of 12 1 2 6 7 8 9 10 11 12
Re: Cost of 900 hp in a N/A small block? [Re: WHITEDART] #1935217
10/19/15 10:03 PM
10/19/15 10:03 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
There has been very few people that have really shown what a R5/P7 engine is capable of. Most guys are buying up cheap ex Nascar parts, rather than starting with new castings etc and doing a full effort build. To that end, it's not an engine that's really proven itself as a drag racing platform.
Alan Jones
Re: Cost of 900 hp in a N/A small block? [Re: 408strokerdart] #1935260
10/19/15 10:59 PM
10/19/15 10:59 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
I think the cost of stroking an R5 is what kills it.
Re: Cost of 900 hp in a N/A small block? [Re: 408strokerdart] #1935367
10/20/15 01:48 AM
10/20/15 01:48 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
LOL uphill in a parking lot. The sad unfortunate truth of it. Be nice to run at a proper race facility but we will next year. Plan on making some trips back east to run NMCA East NA10.5, of course AFTER the engine gets quite a bit smaller first
Re: Cost of 900 hp in a N/A small block? [Re: 408strokerdart] #1955133
11/20/15 11:34 PM
11/20/15 11:34 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
I was talking to Ray Barton today, their gen3 426 ss hemi makes 950 hp.
50k to build
David has set the record again at 8.54 at 3400 lbs
Re: Cost of 900 hp in a N/A small block? [Re: SpareParts] #1955237
11/21/15 06:44 AM
11/21/15 06:44 AM
Deep DEEP SOUTH
LAD 524 Offline
LAD 524  Offline
Deep DEEP SOUTH
Not enough block height for a decent arm.
Re: Cost of 900 hp in a N/A small block? [Re: sixpackgut] #1955528
11/21/15 08:49 PM
11/21/15 08:49 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
50k to build
Needs more like 1075hp to run that number at 3400,950hp @3400 would be an 8.90 0ass.
Re: Cost of 900 hp in a N/A small block? [Re: sixpackgut] #1955532
11/21/15 08:53 PM
11/21/15 08:53 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
50k to build
I wonder if his labor is reflected in this cost or if someone could walk in with 50K and leave with an engine.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Cost of 900 hp in a N/A small block? [Re: fishy340] #1955947
11/22/15 05:49 PM
11/22/15 05:49 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Originally Posted By fishy340
Anyone have video of and 8 sec non tube chassis p7 going 8 anything ?
Check out Bondobobs stock suspension Dart sport. Went 5.82 1/8 mile. That's high 8's.
Re: Cost of 900 hp in a N/A small block? [Re: LA360] #1955965
11/22/15 06:06 PM
11/22/15 06:06 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Cheap NASCAR parts? Windberg cranks, Lentz rods, JEPistons, Titanium valves, retainers, Jesel valve train. All cheap parts, that's why most mopars don't carry this particular list of brands.
That said, Alan is sort of correct. Buy a used R5 that made 830 new. Worn rings, pistons, valves you still make over 800hp. The 575 torque and high RPM is what limits most from making record passes. I for one have not set the world on fire with little or big R5 engines. But, in fairness, I have really not put the same effort a class racer would. Both of my engines 358 or 440 would go 5.5's at 3000 with full exhaust. The 440 would do so with almost no challenge. It went 5.71 first pass in the car. The 358 would take some work. One get rid of the big motor bogging tires. Second put a 3spd auto or stick in the car and know what converter or clutch setup.
Bottom line I have raced the 358 and 440 at a lot of Mopar shows. No one with a comparable combo was outrunning me. Sure it is easily possible. The average Mopar guy spent more to go slower. I would be happy to sit down and compare receipts. So I get a little tired of people talking down the R5. For the money you can't beat it. Wanna make 900 buy one and spend a little money on it. EEI blocks and 4" cranks are available to make it much easier. My 440 will make 900 on the pump. And it is cheaper to build with available NASCAR takeoffs. Build a all new combo as Ernie has done and 1000hp has been done.
Re: Cost of 900 hp in a N/A small block? [Re: pittsburghracer] #1956053
11/22/15 08:19 PM
11/22/15 08:19 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
50k to build
Ray said out the door. By comparison I think an Indy drag pack engine is or was 25k
Re: Cost of 900 hp in a N/A small block? [Re: 408strokerdart] #1956327
11/23/15 04:44 AM
11/23/15 04:44 AM
Southern Missouri
Wailin D Offline
Wailin D  Offline
Southern Missouri
The Indy Drag Pak motor is a cast iron block 5.7/6.1 hemi with 6.1 heads per NHRA rules. The Barton 426 hemi is a special Mopar crate motor package developed for the NHRA Factory Stock class. It is specially machined aluminum block and Apache heads with a larger throttle body. What Ray and David Barton have done with these motors is truly amazing. They not only have the fastest Drag Pak in the land, they have the fastest Factory Stock car in the land. On a side note, a Drag Pak with a 426 Gen III hemi driven by Kevin Helms won the national championship in NHRA Stock Eliminator this year.
Re: Cost of 900 hp in a N/A small block? [Re: 408strokerdart] #1956819
11/23/15 11:57 PM
11/23/15 11:57 PM
Southern Missouri
Wailin D Offline
Wailin D  Offline
Southern Missouri
Should make one quick clarification. Barton is the fastest NA Factory Stock car in the country. There is also a boosted class.
Re: Cost of 900 hp in a N/A small block? [Re: Wailin D] #1956824
11/24/15 12:04 AM
11/24/15 12:04 AM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
Are the Hellcats allowed to run in a stock class yet?
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Cost of 900 hp in a N/A small block? [Re: 408strokerdart] #1957482
11/25/15 02:11 AM
11/25/15 02:11 AM
Southern Missouri
Wailin D Offline
Wailin D  Offline
Southern Missouri
Not yet. This last year NHRA added some new combinations for the Challenger where showroom or street configurations of the 5.7, 6.1 and 6.4 hemis are legal. They haven't approved the street 6.2 supercharged hemi to date. However, the race only 2015 Challenger Drag Pak that came out this year can be ordered with either an NA 426 hemi combo or a 354 supercharged hemi combo. They had to reduce the cubic inches of the supercharged hemi to match the Ford and Chevys. The race ready supercharged Drag Pak will only set you back $110,000.
http://www.mopar.com/dodge/challenger/mopar-drag-pak/
Re: Cost of 900 hp in a N/A small block? [Re: 408strokerdart] #1957490
11/25/15 02:19 AM
11/25/15 02:19 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
What's the thread title again?
Re: Cost of 900 hp in a N/A small block? [Re: LA360] #1958201
11/26/15 10:41 AM
11/26/15 10:41 AM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
x2, the R5 block with a deck reinforcement plate will accept a rather large bore, get a set of new P7 castings, move the exhaust valve moved over to make room for a larger intake valve, and you got something to work with. The NASCAR port/valve/cam programs were never meant to feed anything more than 358 c.i.
Re: Cost of 900 hp in a N/A small block? [Re: 408strokerdart] #1958372
11/26/15 02:55 PM
11/26/15 02:55 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
What cam core would be used on the Ritter block with P7 heads?
I'm interested in building a 400" P7 and if it worked this could be a budget way to do it.
Re: Cost of 900 hp in a N/A small block? [Re: SpareParts] #1958510
11/26/15 09:10 PM
11/26/15 09:10 PM
LA360 Offline
LA360  Offline
It would be a R5 camshaft with a LA style front. They were machining the front of the R5 cores, but depending on what you were wanting to do, a custom core would probably be best.
Alan Jones
Re: Cost of 900 hp in a N/A small block? [Re: 408strokerdart] #1958539
11/26/15 10:34 PM
11/26/15 10:34 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Lol sounds dirt cheap.
Why wouldn't an LA/R3 cam core work? I thought these were Basically r3 blocks that a P7 head would bolt on. But I haven't gotten to read up on these things much
Re: Cost of 900 hp in a N/A small block? [Re: SpareParts] #1958629
11/27/15 01:45 AM
11/27/15 01:45 AM
South Central Pa
webemopes Offline
webemopes  Offline
South Central Pa
p7 is a splayed valve so your valves aren`t arranged ex /in/in/ex/ex/in/in/ex. plus they are 6 bearing 60 mm. you can have the snout machined down for a standard cam drive
