Plug Gap with MSD Digital box
#1949244
11/11/15 05:30 AM
11/11/15 05:30 AM
Posts: 55 West Coast
Pink Dart
West Coast
What kind of plug gaps is everybody running in an Indy headed small block? Just curious Thank You
Aka: Albergetti Indy W2's
Re: Plug Gap with MSD Digital box
[Re: Pink Dart]
#1949271
11/11/15 10:30 AM
11/11/15 10:30 AM
Posts: 20,179 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I have always had good-luck with keeping the gap on my Autolites around .028-.030 and in all my years of racing have never gone over .035 but I run the MSD 7AL3 box. Never really saw a reason to open them up more.
[Re: Pink Dart]
#1949354
11/11/15 01:40 PM
11/11/15 01:40 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
In the old dayz it was .060 w/msd but that seems excessive so .035 seems to work real well n/a at least and NGK`s for me......
[Re: Pink Dart]
#1949397
11/11/15 02:31 PM
11/11/15 02:31 PM
Posts: 6,906 IL, Aurora
ademon
IL, Aurora
I go .045 with the 6AL. Going much bigger than that and the strap is not square with the electrode on most plugs.
[Re: justinp61]
#1949452
11/11/15 04:19 PM
11/11/15 04:19 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
I've ran .035-.045" and saw no difference on my street/strip small block. Same here with my big block,i go 35.
[Re: Pink Dart]
#1949472
11/11/15 04:43 PM
11/11/15 04:43 PM
Posts: 4,457 Washington
madscientist
Washington
Champion C63CX. It has a cut back ground electrode. Go to a lower number if you think you need a colder plug.
[Re: Pink Dart]
#1949743
11/12/15 01:11 AM
11/12/15 01:11 AM
Posts: 10,384 Upstate NY
Bigcube
Upstate NY
Indy Big block, take the NGK plug out of the box and put it in the head. I think they are .030" ish... I don't bother to check them.
[Re: Bigcube]
#1949886
11/12/15 11:25 AM
11/12/15 11:25 AM
Posts: 13,367 Marion, South Carolina [><]
an8sec70cuda
Indy Big block, take the NGK plug out of the box and put it in the head. I think they are .030" ish... I don't bother to check them. Feel free to try whatever gap you want, but if you're not having an issue w/ the spark blowing out due to high cylinder pressure...I don't think you're gonna see a difference.
[Re: Pink Dart]
#1949913
11/12/15 12:31 PM
11/12/15 12:31 PM
Posts: 8,027 Tulsa OK
Bad340fish
Tulsa OK
I talked to MSD tech at dragweek a few years ago. I was having problems with one of there boxes and he recommended I close the plug gap from .035 because there was no power in it. I closed it up and it still misfired but he was very clear that the more gap you have the harder it is on the ignition pieces. I solved my ignition troubles by running away from MSD.
68 Barracuda Formula S 340
[Re: ]
#2027572
03/08/16 11:29 PM
03/08/16 11:29 PM
Posts: 11,586 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
All these Mopars are weak and should be used as boat anchors. Bye. Sorry you had to leave so soon, rice boy.
