Plug Gap with MSD Digital box #1949244
11/11/15 05:30 AM
11/11/15 05:30 AM
West Coast
Pink Dart Offline OP
West Coast
What kind of plug gaps is everybody running in an Indy headed small block?
Just curious
Thank You
Aka: Albergetti
Indy W2's
Re: Plug Gap with MSD Digital box [Re: Pink Dart] #1949271
11/11/15 10:30 AM
11/11/15 10:30 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I have always had good-luck with keeping the gap on my Autolites around .028-.030 and in all my years of racing have never gone over .035 but I run the MSD 7AL3 box. Never really saw a reason to open them up more.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Plug Gap with MSD Digital box [Re: Pink Dart] #1949354
11/11/15 01:40 PM
11/11/15 01:40 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
In the old dayz it was .060 w/msd but that seems excessive so .035 seems to work real well n/a at least and NGK`s for me......
Re: Plug Gap with MSD Digital box [Re: Pink Dart] #1949395
11/11/15 02:29 PM
11/11/15 02:29 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I've ran .035-.045" and saw no difference on my street/strip small block.
Re: Plug Gap with MSD Digital box [Re: Pink Dart] #1949397
11/11/15 02:31 PM
11/11/15 02:31 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
I go .045 with the 6AL. Going much bigger than that and the strap is not square with the electrode on most plugs.
Re: Plug Gap with MSD Digital box [Re: justinp61] #1949452
11/11/15 04:19 PM
11/11/15 04:19 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
Same here with my big block,i go 35.
Re: Plug Gap with MSD Digital box [Re: Pink Dart] #1949472
11/11/15 04:43 PM
11/11/15 04:43 PM
Washington
madscientist Offline
Washington
Champion C63CX. It has a cut back ground electrode. Go to a lower number if you think you need a colder plug.
Re: Plug Gap with MSD Digital box [Re: Pink Dart] #1949552
11/11/15 07:06 PM
11/11/15 07:06 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Keep opening them up till the et falls off. Has a lot to do on how fast a coil you have. Make sure you have sharp, flat, squared edges, spark does not like round corners.
Re: Plug Gap with MSD Digital box [Re: Pink Dart] #1949743
11/12/15 01:11 AM
11/12/15 01:11 AM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Indy Big block, take the NGK plug out of the box and put it in the head. I think they are .030" ish... I don't bother to check them.
Re: Plug Gap with MSD Digital box [Re: Bigcube] #1949886
11/12/15 11:25 AM
11/12/15 11:25 AM
an8sec70cuda Offline
iagree Feel free to try whatever gap you want, but if you're not having an issue w/ the spark blowing out due to high cylinder pressure...I don't think you're gonna see a difference.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Plug Gap with MSD Digital box [Re: Pink Dart] #1949911
11/12/15 12:29 PM
11/12/15 12:29 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
I have a buddy that works at Roush, for what is worth he told me they have spent a lot of time experimenting with gaps. In the end he told me there is so little gain, they don't even worry about it most of the time. Big gaps can cause issues (spark blowout) , and small gaps don't hurt power.
Re: Plug Gap with MSD Digital box [Re: Pink Dart] #1949913
11/12/15 12:31 PM
11/12/15 12:31 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I talked to MSD tech at dragweek a few years ago. I was having problems with one of there boxes and he recommended I close the plug gap from .035 because there was no power in it. I closed it up and it still misfired but he was very clear that the more gap you have the harder it is on the ignition pieces. I solved my ignition troubles by running away from MSD.
68 Barracuda Formula S 340
Re: Plug Gap with MSD Digital box [Re: ] #2027572
03/08/16 11:29 PM
03/08/16 11:29 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Originally Posted By Pimp
All these Mopars are weak and should be used as boat anchors.
Bye. Sorry you had to leave so soon, rice boy.
