Cross Ram Intake #1946192
11/06/15 11:46 AM
11/06/15 11:46 AM
Nashville, Tennessee
Tempest Offline OP
Tempest  Offline OP
Any difference between the A&A and Mancini 440 intake for quality, fitment etc?
Re: Cross Ram Intake [Re: Tempest] #1946195
11/06/15 11:52 AM
11/06/15 11:52 AM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
They are the same ones.
JAKES AUTOMOTIVE
Re: Cross Ram Intake [Re: JAKE68] #1946257
11/06/15 01:07 PM
11/06/15 01:07 PM
Tempest Offline OP
Tempest  Offline OP
Thank you.
Re: Cross Ram Intake [Re: Tempest] #1946279
11/06/15 01:55 PM
11/06/15 01:55 PM
Minn
SportF Offline
SportF  Offline
Minn
A&A manifolds are beautiful! There is a neat story Rick tells when he showed one of the first manifolds to a Chrysler executive, who thought it was a new old stock manifold! Its a great piece that looks perfect!
Re: Cross Ram Intake [Re: Tempest] #1946678
11/06/15 11:49 PM
11/06/15 11:49 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
here's a picture of A&A intake vs the Mopar Performance
Re: Cross Ram Intake [Re: nss guy] #1946680
11/06/15 11:52 PM
11/06/15 11:52 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
the unpainted is A&A, and yeah it's lower and closer to original plus faster
Re: Cross Ram Intake [Re: Tempest] #1946907
11/07/15 01:48 PM
11/07/15 01:48 PM
New York
polyspheric Offline
polyspheric  Offline
New York
How different is the box volume?
Boffin Emeritus
Re: Cross Ram Intake [Re: nss guy] #1946998
11/07/15 04:11 PM
11/07/15 04:11 PM
The original stock 1964 intakes where better(faster at the drags) than the 1962/63 even if you had converted the early intakes for the bigger 1964 3705 Carter carbs. IHTHs I never had or owned or race a A&A repop intake shruggy
Re: Cross Ram Intake [Re: Tempest] #1947187
11/07/15 09:44 PM
11/07/15 09:44 PM
Tempest Offline OP
Tempest  Offline OP
To clarify, I'm not talking about original. I'm asking about the 440 repro intakes on stock size ports.
Re: Cross Ram Intake [Re: Tempest] #1947213
11/07/15 10:19 PM
11/07/15 10:19 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
The A&A manifold is based on the 1964 intake. They make it in 3 versions. As cast 440 ports, cnc 440 ports and as cast max wedge ports. I'm pretty sure Guy replaced a Mopar performance reproduction manifold with the A&A and picked up a tenth or so. He is running the max wedge port intake.
Getting old just means you were smarter than some and luckier than others.
Re: Cross Ram Intake [Re: dannysbee] #1947317
11/08/15 12:44 AM
11/08/15 12:44 AM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
exactly as stated, before the mopar performance intake I ran an original 63 intake that had the the 4 hole centers cut out for the larger bore carbs, the A&A is definitely faster then the mopar performance and the original intakes. now the 440 port intake ??? what are you going to compare it to? the look is perfect, performance ????
Re: Cross Ram Intake [Re: nss guy] #1947437
11/08/15 11:27 AM
11/08/15 11:27 AM
Tempest Offline OP
Tempest  Offline OP
My initial question was regarding fitment and quality.
Re: Cross Ram Intake [Re: Tempest] #1947470
11/08/15 01:01 PM
11/08/15 01:01 PM
New York
polyspheric Offline
polyspheric  Offline
New York
There are reasons other than manifold improvements why it may be faster.
Boffin Emeritus
Re: Cross Ram Intake [Re: Tempest] #1947498
11/08/15 01:45 PM
11/08/15 01:45 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
I have never seen a post with any complaints on either.
Re: Cross Ram Intake [Re: Tempest] #1947503
11/08/15 01:58 PM
11/08/15 01:58 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
According to this article the 440 port intake is not a slug performance wise.
http://www.hotrod.com/cars/project-vehicles/ccrp-0711-1964-mopar/
Re: Cross Ram Intake [Re: nss guy] #1947592
11/08/15 04:26 PM
11/08/15 04:26 PM
Every Max Wedge motor that I have heard of or seen at the races with the centers cut out where dogs compared to the same cars with the stock intake and same carbs on them work shruggy
