Re: Cross Ram Intake
[Re: Tempest]
#1946907
11/07/15 01:48 PM
11/07/15 01:48 PM
Posts: 4,210 New York
polyspheric
New York
How different is the box volume?
Boffin Emeritus
[Re: Tempest]
#1947213
11/07/15 10:19 PM
11/07/15 10:19 PM
Posts: 5,160 Texas
dannysbee
Texas
The A&A manifold is based on the 1964 intake. They make it in 3 versions. As cast 440 ports, cnc 440 ports and as cast max wedge ports. I'm pretty sure Guy replaced a Mopar performance reproduction manifold with the A&A and picked up a tenth or so. He is running the max wedge port intake.
Getting old just means you were smarter than some and luckier than others.
[Re: dannysbee]
#1947317
11/08/15 12:44 AM
11/08/15 12:44 AM
Posts: 1,443 central ohio
nss guy
central ohio
The A&A manifold is based on the 1964 intake. They make it in 3 versions. As cast 440 ports, cnc 440 ports and as cast max wedge ports. I'm pretty sure Guy replaced a Mopar performance reproduction manifold with the A&A and picked up a tenth or so. He is running the max wedge port intake. exactly as stated, before the mopar performance intake I ran an original 63 intake that had the the 4 hole centers cut out for the larger bore carbs, the A&A is definitely faster then the mopar performance and the original intakes. now the 440 port intake ??? what are you going to compare it to? the look is perfect, performance ????
[Re: nss guy]
#1947437
11/08/15 11:27 AM
11/08/15 11:27 AM
Posts: 595 Nashville, Tennessee
Tempest
The A&A manifold is based on the 1964 intake. They make it in 3 versions. As cast 440 ports, cnc 440 ports and as cast max wedge ports. I'm pretty sure Guy replaced a Mopar performance reproduction manifold with the A&A and picked up a tenth or so. He is running the max wedge port intake. exactly as stated, before the mopar performance intake I ran an original 63 intake that had the the 4 hole centers cut out for the larger bore carbs, the A&A is definitely faster then the mopar performance and the original intakes. now the 440 port intake ??? what are you going to compare it to? the look is perfect, performance ???? My initial question was regarding fitment and quality.
[Re: Tempest]
#1947470
11/08/15 01:01 PM
11/08/15 01:01 PM
polyspheric
New York
There are reasons other than manifold improvements why it may be faster.
Boffin Emeritus
[Re: Tempest]
#1947498
11/08/15 01:45 PM
11/08/15 01:45 PM
Posts: 5,160 Texas
dannysbee
Texas
The A&A manifold is based on the 1964 intake. They make it in 3 versions. As cast 440 ports, cnc 440 ports and as cast max wedge ports. I'm pretty sure Guy replaced a Mopar performance reproduction manifold with the A&A and picked up a tenth or so. He is running the max wedge port intake. exactly as stated, before the mopar performance intake I ran an original 63 intake that had the the 4 hole centers cut out for the larger bore carbs, the A&A is definitely faster then the mopar performance and the original intakes. now the 440 port intake ??? what are you going to compare it to? the look is perfect, performance ???? My initial question was regarding fitment and quality. I have never seen a post with any complaints on either.
