Rocker shaft studs #1945508
11/05/15 05:42 AM
11/05/15 05:42 AM
lancaster,california
johnnycuda Offline OP
Hey guys, was wondering if any of you have ever used rocker shaft studs?, I have Indy SR heads and recently bought the Comp Cams Ultra Pro Magnum rocker kit, I believe the bolts provided are most likely intended for iron/stock heads, as two of the bolts per side seem to just catch the threads by a couple.
The end bolt holes in the heads are farther sunk into the head than the center three, so they need to be longer.
This past weekend on the Hot Rod Drag Weekend I had valvetrain noise, checked the shaft bolts and the end one stripped, thought it would be stronger to use studs, instead of bolts. I drilled out and installed a helicoil this evening in the stripped hole.
Being a Indy head, the oil is fed thru the back of the head via a hose,instead of up thru the second bolt as stock.
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT!
1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air,
New daily driver-2003 Ram 2500 Cummins 5.9
'69 Valiant 2-dr, sleeper!
New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
Re: Rocker shaft studs [Re: johnnycuda] #1945529
11/05/15 10:00 AM
11/05/15 10:00 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Studs are the only way to go with aluminum heads,IMO. Indy sells their own stud kit, but ARP hardware is nicer if you can match the two different brands lengths.
Re: Rocker shaft studs [Re: BradH] #1945533
11/05/15 10:08 AM
11/05/15 10:08 AM
glendora, ca.
Deepockets Offline
Deepockets  Offline
glendora, ca.
I used the indy over the T&D stud since the indy's were longer giving more thread engagement.
Re: Rocker shaft studs [Re: johnnycuda] #1945588
11/05/15 12:09 PM
11/05/15 12:09 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
I run SR heads with Harland Sharp rockers. I use studs and would not have it any other way.
Re: Rocker shaft studs [Re: johnnycuda] #1945651
11/05/15 02:13 PM
11/05/15 02:13 PM
NE Ohio
DoubleD Online content
DoubleD  Online Content
NE Ohio
I posted this awhile back - I used these on a set of INDY EZ-1 heads
You can order ARP stuff and make your own kit - these are Summit part numbers - I just used these for my HS rockers
ARP-200-8556 WASHER 10-PC comes in a package
ARP-300-8332 12 PT NUTS 10PC comes in a package
ARP-AJ2500-1B STUD 3/8 X 2.500 – you need 6 of these
ARP-AJ3250-1B SHAFT STUD – 3/8 x 3.25 you need 4 of these
Re: Rocker shaft studs [Re: BradH] #1945678
11/05/15 03:10 PM
11/05/15 03:10 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Yep.............had a local machinist order a set from ARP for my RPM`s.......
Re: Rocker shaft studs [Re: DoubleD] #1945698
11/05/15 03:37 PM
11/05/15 03:37 PM
You sir, are The Man!, I drilled and heli-coiled it last night, took measurements to call into ARP this morning, and here you are posting this, very cool and appreciated. We have a ARP account here, so I ordered these direct, get them tomorrow for the weekend.
Re: Rocker shaft studs [Re: johnnycuda] #1946302
11/06/15 02:34 PM
11/06/15 02:34 PM
AndyF Offline
AndyF  Offline
The new Trick Flow heads require 10 studs which are all the same length. I mocked my heads up with 2.500 studs and then decided that 2.750 would work better.
