Rocker shaft studs
#1945508
11/05/15 05:42 AM
11/05/15 05:42 AM
Posts: 860 lancaster,california
johnnycuda
Hey guys, was wondering if any of you have ever used rocker shaft studs?, I have Indy SR heads and recently bought the Comp Cams Ultra Pro Magnum rocker kit, I believe the bolts provided are most likely intended for iron/stock heads, as two of the bolts per side seem to just catch the threads by a couple. The end bolt holes in the heads are farther sunk into the head than the center three, so they need to be longer. This past weekend on the Hot Rod Drag Weekend I had valvetrain noise, checked the shaft bolts and the end one stripped, thought it would be stronger to use studs, instead of bolts. I drilled out and installed a helicoil this evening in the stripped hole. Being a Indy head, the oil is fed thru the back of the head via a hose,instead of up thru the second bolt as stock.
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT! 1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air, New daily driver-2003 Ram 2500 Cummins 5.9 '69 Valiant 2-dr, sleeper! New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
Re: Rocker shaft studs
[Re: johnnycuda]
#1945588
11/05/15 12:09 PM
11/05/15 12:09 PM
Posts: 4,270 Morrow, OH
markz528
Morrow, OH
I run SR heads with Harland Sharp rockers. I use studs and would not have it any other way.
[Re: BradH]
#1945678
11/05/15 03:10 PM
11/05/15 03:10 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
Studs are the only way to go with aluminum heads,IMO. Indy sells their own stud kit, but ARP hardware is nicer if you can match the two different brands lengths. Yep.............had a local machinist order a set from ARP for my RPM`s.......
[Re: DoubleD]
#1945698
11/05/15 03:37 PM
11/05/15 03:37 PM
johnnycuda
You sir, are The Man!, I drilled and heli-coiled it last night, took measurements to call into ARP this morning, and here you are posting this, very cool and appreciated. We have a ARP account here, so I ordered these direct, get them tomorrow for the weekend. I posted this awhile back - I used these on a set of INDY EZ-1 heads
You can order ARP stuff and make your own kit - these are Summit part numbers - I just used these for my HS rockers
ARP-200-8556 WASHER 10-PC comes in a package ARP-300-8332 12 PT NUTS 10PC comes in a package ARP-AJ2500-1B STUD 3/8 X 2.500 – you need 6 of these ARP-AJ3250-1B SHAFT STUD – 3/8 x 3.25 you need 4 of these
