Re: Prepped verses no-prepped tracks
[Re: Crizila]
#1943255
11/01/15 10:11 PM
11/01/15 10:11 PM
Posts: 525 Can , Nova Scotia , Cape Breto...
caper
WHY the attitude?
Nobody is hating on the racers who want to race on a no-prep track. Personally, I don't see why you would build a car with all that hard earned money and race on a surface that you are going to skate all the way to the end. Also, why you would build a car with all that power and not be able to put all of it to the ground. I am just looking at the logic of it all. I did not say that I didn't like it.
New best 10.18 , 1.40 60 ft 496 Scott Brown built, street driven 3600 lbs,654 hp , 653 ft tq
[Re: nss guy]
#1943288
11/01/15 10:46 PM
11/01/15 10:46 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
There's a lot of comments here that just don't make sense.
You guys act like you race a radial prep track with 33x16's. You don't. Most tracks blow the track off run a Friday TNT. Saturday blow it off again, spray 100-330 ft and you race. The rubber from the race cars and years of vht are what makes the tire stick. You run a given track tune your chassis and race.
Race a big tire big power car, such as Pro mod, on radial prep. It will shake apart. Like racing a radial with full power on a bracket race prep.
No prep on a good track is mostly a gimmick. You scrape all the rubber up. The track is sticky after a good burnout. We have a local track that is a struggle with any heads up car on a regular bracket Sunday. Big power cars struggle not to loose it on top end. They had a no prep race. Pretty interesting first round like any heads up race. After that the track tightened up and racers adjusted. The numbers were within .2 of any other track.
Vht is not a safety measure. It's just what your used to.
[Re: justinp61]
#1943406
11/02/15 01:05 AM
11/02/15 01:05 AM
Posts: 7,506 Az
Crizila
Az
Bottom line is this, if you don't like it, don't race it. Pretty simple. Yep!
Fastest 300
[Re: caper]
#1943438
11/02/15 02:19 AM
11/02/15 02:19 AM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
WHY the attitude?
No hating?........Really?.........maybe you should go back and read some of the posts. Like why not hose it down and let it freeze, etc. Small tire and no prep racing has been called "stupid", and about any other adjective you want to think of on this site more times than I can count. Seen them called "guard rail magnets" and all kinds of other clever nicknames. What people "like" to do is a relative thing. I don't see why guys build 1200hp motors in ex pro-Stockers and go run it in a 9.90 index class.......but I don't call them "stupid" because they do it. Why build a Top Fuel car? 10,000 HP can't possibly be put to the ground without power management and is why top crew chiefs make a million dollars a year. Small tire and no-prep racing is challenging, some like a challenge. Anybody with enough money and decent smarts, can buy the best parts money can buy and go pretty fast on a flypaper track. Going fast on a marginal surface when the track is the equalizer is a whole new ballgame
[Re: Crizila]
#1943551
11/02/15 11:30 AM
11/02/15 11:30 AM
Posts: 1,260 New Mexico
Adobedude
New Mexico
Sounds like a fun event to watch, wreck, clean the track for two hours, wreck clean the track for two hours.... Maybe they should call it NASCAR.
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
[Re: Crizila]
#1943560
11/02/15 11:37 AM
11/02/15 11:37 AM
Posts: 1,237 North Central, Indiana
Roughbird72
Are most if not all off these races 1/8 mile only?
Now that i think about it, the traction couldn't be much worse than TnT at a local track here ... blow off the starting line, spray to the 60' once, blow the starting off at breaks & lots of street tired cars making the starting line a mess.
72 Plymouth Roadrunner 11.08@123.25
[Re: Adobedude]
#1943563
11/02/15 11:41 AM
11/02/15 11:41 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Sounds like a fun event to watch, wreck, clean the track for two hours, wreck clean the track for two hours.... Maybe they should call it NASCAR. You race at the wrong track if it takes two hours to clean the track!!
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 1967dartgt]
#1943569
11/02/15 11:51 AM
11/02/15 11:51 AM
Adobedude
New Mexico
I was going to say half an hour but left it at two thinking no one will take me literally.
[Re: SpareParts]
#1943586
11/02/15 12:19 PM
11/02/15 12:19 PM
Roughbird72
Up here we have 2 classes that run 1/4 mile no prep, one of the cars is known to go 7.80's on a 26" slick and he's been beat a few times now (while making a clean pass) That'd be a 4.95-5.0 1/8 Safe is a relative term,but wouldn't running the 1/8 & keeping actual street tires off the track be somewhat safer?
[Re: Crizila]
#1943737
11/02/15 04:11 PM
11/02/15 04:11 PM
Posts: 684 St. Charles, MO.
Slingshot383
St. Charles, MO.
Go back to the days of doing a burnout, then a VHT hit, then stage and go, the track does nothing other than brooming the track and dragging it. Could add powdered rosin (gold dust) burnouts across the starting line again.
1994 Undercover Chassis 125" altered
stack injected big block, soon blown and injected
Member of The Torque and Recoil Club
[Re: Roughbird72]
#1943898
11/02/15 08:17 PM
11/02/15 08:17 PM
Posts: 1,563 Janesville, WI
SpareParts
Janesville, WI
Up here we have 2 classes that run 1/4 mile no prep, one of the cars is known to go 7.80's on a 26" slick and he's been beat a few times now (while making a clean pass) That'd be a 4.95-5.0 1/8 Safe is a relative term,but wouldn't running the 1/8 & keeping actual street tires off the track be somewhat safer? Yeah, at t KOTS event there are 2 slower classes both on 26" tires and a Sr group that are 1/8 mile on 28's. Some of those cars that class race have gone high 6's in NMCA classes. When they got real quick the drivers requested 1/8
[Re: SpareParts]
#1943906
11/02/15 08:28 PM
11/02/15 08:28 PM
Posts: 5,102 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
I don't have a dog in this fight and don't make any where near enough power to worry about prep. Saturday a messed up thing happened though...I was lined up against about a 2011 Cadillac CTS with a tune and street tires running about 11.90's. Just past the 330 where they stopped prep he lost it behind me. Had I not treed him he would have clipped me in the LR. I caught a glimpse of his car in my mirror in my lane sideways about a car length behind me. He didn't hit anything and didn't make any runs after that...maybe he only brought one pair of underwear... From an outsiders point of view it seems like prep is a crutch...but I'm wrong numerous times daily...
...FAFO...
