Page 3 of 3 1 2 3
Re: Prepped verses no-prepped tracks [Re: Crizila] #1943255
11/01/15 10:11 PM
11/01/15 10:11 PM
Can , Nova Scotia , Cape Breto...
caper Offline
caper  Offline
WHY the attitude?
Nobody is hating on the racers who want to race on a no-prep track. Personally, I don't see why you would build a car with all that hard earned money and race on a surface that you are going to skate all the way to the end. Also, why you would build a car with all that power and not be able to put all of it to the ground. I am just looking at the logic of it all. I did not say that I didn't like it.
New best 10.18 , 1.40 60 ft 496 Scott Brown built, street driven 3600 lbs,654 hp , 653 ft tq
Re: Prepped verses no-prepped tracks [Re: caper] #1943265
11/01/15 10:19 PM
11/01/15 10:19 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
this is what the ignition boxes with all the bells and whistles are for. slew the rpm, timing , etc. Davis traction control..
that's why the sh$t ain't legal for regular bracket racing
Re: Prepped verses no-prepped tracks [Re: nss guy] #1943288
11/01/15 10:46 PM
11/01/15 10:46 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
There's a lot of comments here that just don't make sense.
You guys act like you race a radial prep track with 33x16's. You don't. Most tracks blow the track off run a Friday TNT. Saturday blow it off again, spray 100-330 ft and you race. The rubber from the race cars and years of vht are what makes the tire stick. You run a given track tune your chassis and race.
Race a big tire big power car, such as Pro mod, on radial prep. It will shake apart. Like racing a radial with full power on a bracket race prep.
No prep on a good track is mostly a gimmick. You scrape all the rubber up. The track is sticky after a good burnout. We have a local track that is a struggle with any heads up car on a regular bracket Sunday. Big power cars struggle not to loose it on top end. They had a no prep race. Pretty interesting first round like any heads up race. After that the track tightened up and racers adjusted. The numbers were within .2 of any other track.
Vht is not a safety measure. It's just what your used to.
Re: Prepped verses no-prepped tracks [Re: caper] #1943298
11/01/15 10:56 PM
11/01/15 10:56 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Originally Posted By caper
WHY the attitude?
First off I don't race no prep events, although show up at my local track with radials and it's like racing on a wet road.
To me it's like eating raw oysters, no way I'll waste my money on them but other people love them. It's all about doing what you like, whether it's eating raw oysters or racing at a no prep event. twocents up
Re: Prepped verses no-prepped tracks [Re: justinp61] #1943406
11/02/15 01:05 AM
11/02/15 01:05 AM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Originally Posted By justinp61
Bottom line is this, if you don't like it, don't race it. Pretty simple.
Yep!
Fastest 300
Re: Prepped verses no-prepped tracks [Re: Crizila] #1943412
11/02/15 01:15 AM
11/02/15 01:15 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Lol I'll be on a 26" radial and no prep next year for at least 2 events. I probably have more power than the guys here hating on the no prep/grudge scene
Re: Prepped verses no-prepped tracks [Re: caper] #1943438
11/02/15 02:19 AM
11/02/15 02:19 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
WHY the attitude?
No hating?........Really?.........maybe you should go back and read some of the posts. Like why not hose it down and let it freeze, etc. Small tire and no prep racing has been called "stupid", and about any other adjective you want to think of on this site more times than I can count. Seen them called "guard rail magnets" and all kinds of other clever nicknames. What people "like" to do is a relative thing. I don't see why guys build 1200hp motors in ex pro-Stockers and go run it in a 9.90 index class.......but I don't call them "stupid" because they do it. Why build a Top Fuel car? 10,000 HP can't possibly be put to the ground without power management and is why top crew chiefs make a million dollars a year.
Small tire and no-prep racing is challenging, some like a challenge. Anybody with enough money and decent smarts, can buy the best parts money can buy and go pretty fast on a flypaper track. Going fast on a marginal surface when the track is the equalizer is a whole new ballgame
Re: Prepped verses no-prepped tracks [Re: Crizila] #1943551
11/02/15 11:30 AM
11/02/15 11:30 AM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
Sounds like a fun event to watch, wreck, clean the track for two hours, wreck clean the track for two hours....
Maybe they should call it NASCAR.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: Prepped verses no-prepped tracks [Re: Crizila] #1943560
11/02/15 11:37 AM
11/02/15 11:37 AM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
Are most if not all off these races 1/8 mile only?
Now that i think about it, the traction couldn't be much worse than TnT at a local track here ... blow off the starting line, spray to the 60' once, blow the starting off at breaks & lots of street tired cars making the starting line a mess.
72 Plymouth Roadrunner 11.08@123.25
Re: Prepped verses no-prepped tracks [Re: Adobedude] #1943563
11/02/15 11:41 AM
11/02/15 11:41 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
You race at the wrong track if it takes two hours to clean the track!!
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Prepped verses no-prepped tracks [Re: Crizila] #1943565
11/02/15 11:43 AM
11/02/15 11:43 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Up here we have 2 classes that run 1/4 mile no prep, one of the cars is known to go 7.80's on a 26" slick and he's been beat a few times now (while making a clean pass)
Re: Prepped verses no-prepped tracks [Re: 1967dartgt] #1943569
11/02/15 11:51 AM
11/02/15 11:51 AM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
I was going to say half an hour but left it at two thinking no one will take me literally.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
Re: Prepped verses no-prepped tracks [Re: SpareParts] #1943586
11/02/15 12:19 PM
11/02/15 12:19 PM
Roughbird72 Offline
Roughbird72  Offline
That'd be a 4.95-5.0 1/8
Safe is a relative term,but wouldn't running the 1/8 & keeping actual street tires off the track be somewhat safer? shruggy
Re: Prepped verses no-prepped tracks [Re: Crizila] #1943737
11/02/15 04:11 PM
11/02/15 04:11 PM
St. Charles, MO.
Slingshot383 Offline
St. Charles, MO.
Go back to the days of doing a burnout, then a VHT hit, then stage and go, the track does nothing other than brooming the track and dragging it. Could add powdered rosin (gold dust) burnouts across the starting line again.
1994 Undercover Chassis 125" altered stack injected big block, soon blown and injected Member of The Torque and Recoil Club
Re: Prepped verses no-prepped tracks [Re: Roughbird72] #1943898
11/02/15 08:17 PM
11/02/15 08:17 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Yeah, at t KOTS event there are 2 slower classes both on 26" tires and a Sr group that are 1/8 mile on 28's. Some of those cars that class race have gone high 6's in NMCA classes. When they got real quick the drivers requested 1/8
Re: Prepped verses no-prepped tracks [Re: SpareParts] #1943906
11/02/15 08:28 PM
11/02/15 08:28 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
I don't have a dog in this fight and don't make any where near enough power to worry about prep.
Saturday a messed up thing happened though...I was lined up against about a 2011 Cadillac CTS with a tune and street tires running about 11.90's. Just past the 330 where they stopped prep he lost it behind me. Had I not treed him he would have clipped me in the LR. I caught a glimpse of his car in my mirror in my lane sideways about a car length behind me. He didn't hit anything and didn't make any runs after that...maybe he only brought one pair of underwear... shruggy
From an outsiders point of view it seems like prep is a crutch...but I'm wrong numerous times daily... twocents
...FAFO...
Re: Prepped verses no-prepped tracks [Re: Crizila] #1943958
11/02/15 10:00 PM
11/02/15 10:00 PM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
Years ago - the tracks were all no-prep, unless you consider somebody taking a broom and knocking the biggest pebbles and rocks off the starting line. I used to get to the track an hour before the gates opened and sweep my own lane. I'd line up right against the wall and everybody thought I was crazy. Maybe I was, but I had a better chance of hooking then the guys that lined up centered in the lane.
At Phoenix Dragway in the 70's - you'd drive down a couple miles of gravel/dirt road to get there, then pit in the rocks and gravel as well. All those rocks got drug up onto the racing surface the entire time. It truly was NO PREP.
Page 3 of 3 1 2 3
