Re: Decode my Hemi 4 speed stamping
[Re: Alaskan_TA]
#1943262
11/01/15 10:15 PM
11/01/15 10:15 PM
Posts: 704 USA
rftroy
USA
Why couldn't it be from a Challenger? Also, an 18 spline wouldn't be in a Barracuda. Bob
AAR 4-speed 3.91, Tor-Red; 70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy; 68 Formula S conv 383 4-speed 3.23, Electric Blue; 69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue; 78 Lil' Red Truck, Red; 70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
[Re: KillerBee]
#1943281
11/01/15 10:37 PM
11/01/15 10:37 PM
Posts: 6,497 N.E. Ohio
KillerBee
N.E. Ohio
Very interesting...I guess I now have two 4 speed transmissions from 1970 Cuda's. Thanks for the info guys. I bought this transmission many many years ago and it was attached to this 11" bell housing which I assume is for 1968? The transmission has worked flawlessly for many years in my 440 powered street/strip 1973 Challenger and now will probably find it's way into my 1971 R/T Challenger. Barry or anyone else if you can find the original car it came from it obviously would be for sale, otherwise I'll keep it.
[Re: rftroy]
#1943285
11/01/15 10:45 PM
11/01/15 10:45 PM
Posts: 29,656 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
Why couldn't it be from a Challenger? Because it isn't. Also, an 18 spline wouldn't be in a Barracuda.
If you assume it has never been apart before, but I try not to assume anything which is why I mentioned the case itself. Barry or anyone else if you can find the original car it came from it obviously would be for sale, otherwise I'll keep it. I added it to my database, so if the car shows up at some point I'll give you a shout for sure.
[Re: Alaskan_TA]
#1943305
11/01/15 11:01 PM
11/01/15 11:01 PM
KillerBee
N.E. Ohio
Thanks Barry. Can you verify this 23 spline E-body transmission was also from a 1970 'Cuda. I pulled it many years ago from what looked like an original 340 drivetrain in a 1970 'Cuda heading off to the junkyard. Add it to your list but I doubt the car is still around today but you never know.....
